X18-R Nitro
Cagllari Pocket Bike?
Minipocketrockets.com?
x-7 bullet my 1st bike
make my bike fast!
how to get my cag to 40mph
Old 2 Weeks Ago   #1
MxKid98's Avatar
Gearing Question
I kno the stock gearing for a cag is 7/68 what is a pretty good gearing for more accelleration?
MxKid98 is offline   Reply With Quote
Old 2 Weeks Ago   #2
SPB Mod Master
Re: Gearing Question
You could try leaving the stock gearing and changing the clutch springs to stiffer ones for a higher takeoff rpm to see if that will work better for you but if you want change gearing get a 6 tooth pinion...That will be plenty but be prepared to go atleast 2-3mphs slower on the top end...Peace
Old 2 Weeks Ago   #3
MxKid98's Avatar
is the more teeth on the sprockets more speed or more accelleration?
Old 2 Weeks Ago   #4
Ozmo's Avatar
More teeth on the rear sprocket = more acceleration ,less top speed.
I wouldn't recommend running a 6 tooth front sprocket, from my experience they add allot of stress to your chain, which means your chain wont last as long. The 7 tooth front front sprocket is allot less stress on your chain.
I run 7 front and 66 rear on both my bikes, one of my bikes is a mostly stock 49cc and the other bike is a 2 piece high compression 5 port head setup. But both run about 32-33 mph with decent low end power.
I would suggest a 7 front and a 70 something rear sprocket for better acceleration, less top end speed.
Also by adding more teeth you will have to think about buying a longer chain, depending on how much room you have for adjustment with your setup as it is now.
Ozmo is offline   Reply With Quote
Old 2 Weeks Ago   #5
MxKid98's Avatar
aright cool thanks ozmo
Old 2 Weeks Ago   #6
Hooligan
SpyGuy's Avatar
For gearing, Cags do well with the 1-to-10 rule. One tooth on the pinion equals ten(ish) on the sprocket. Pretty much anything in the 7/70 range will do ya fine, like 7/74, 7/76.
How big a sprocket can you put on these things, anyway? Always wondered about that, and what the biggest one was .... Can you imagine the torque you'd get outta the thing?
Page generated in 0.21131 seconds with 33 queries
