X18-R Nitro
Cagllari Pocket Bike?
something different here look! Custom Quad.
Minipocketrockets.com?
x-7 bullet my 1st bike
make my bike fast!
Old 11-19-2009   #1
Question
If I lost my key to my x15 and its in the off position will that make the bike kill out when i start it up
jeyz is offline   Reply With Quote
Old 11-19-2009   #2
PBP Administrator
nick's Avatar
Re: Question
Yes, It will create a break (An open) in that circuit, What would need to be done is to bypass the key lock all together and connect the two proper wires and the bike would run, Then you either pull the wires apart or add a kill switch to stop the engine.
Nick.
Old 11-19-2009   #3
SPB Mod Master
Re: Question
Just pull the ignition plugs apart and kickstart it.To kill it hook them back up..Hopefully youll remember where you put the key.........Peace
Old 11-21-2009   #4
Re: Question
thanks for the help i got it to start but found out something is wrong with my carb since i switch carb with a dirtbike i have and it ran fine now i have to find why it dies out with my original carb i already took it apart to clean so im guessing its the float...any help would be nice....also my back rim is shot to hell my bolts broke in them so i made new holes but then the bolts from the new hole vibrated out and bent....so i need to buy a new back rim and good places to buy online would be a big help
Old 11-21-2009   #5
SPB Mod Master
Re: Question
Float setting is 10 degrees.....For the rear rim try scooterparts,sdscooters or X-18parts
Old 11-21-2009   #6
Re: Question
which way i have to hold the carb to measure the float...and thanks for the info for the rim
Old 11-21-2009   #7
SPB Mod Master
Re: Question
The best and fastest way would be to eyeball your float to the float in the picture but if you want to measure it out the method is below;-sorry about the pic quality but thats what 3/4 of my pics that got recovered from my last severe harddrive crash looks like now......Good luck
Old 11-21-2009   #8
Re: Question
thanks am2 your alot of help with these bike hopefully the bikes will run now
Page generated in 0.43716 seconds with 39 queries
