x7 Help needed
clutch upgrade? what to do
my bike wont accelerate
no fuel to carb, help!
No electric start on x7
110, 35mph! bs!
Old 03-21-2009   #1
i bought hp carb it came with a spring and i have no clue where it goes can someone help
spyderacer2002 is offline   Reply With Quote
Old 03-21-2009   #2
hamm702's Avatar
Re: 49cc high performance carburetor
hamm702 is offline   Reply With Quote
Old 03-21-2009   #3
dragonkeep2000's Avatar
is it for a cag or a x series pocket bike......? the figure is for a cag 47cc carb............for a piston port engine the spring goes on the throttle cable ontop the carb to help with retraction of the cable
Old 03-22-2009   #4
thats not the kind of carb i bought,my bike is a fs-509 cateye and the carb didnt come with the needle do i have to use my old one from my origanl carb
Old 03-22-2009   #5
StrayDawg63's Avatar
There's not a needle with your type of carb. Just take the spring and slip it over the cable before you hook it up to the carb.
Old 03-22-2009   #6
i brought a hp performencse carb from usa pocketrockets.com and it did not come with a needle or spring but i have the old one, and how do i connect the accelerater cord in the carb it is a slim opening i dont know how the spring and cord connect.
weed17 is offline   Reply With Quote
Old 03-22-2009   #7
Unhappy Re: 49cc high performance carburetor
i brought a hp carb from minibikepartsnow and it did not com with the needle,spring or trottel valve and the new one has a slim opening , the old one has a hole opening were the needle,spring and throttle valve gos in and a top that scerws on the new one just has a long tiny opening i dont know how to connect the throttle inside the carb.do i use the old needle spring and throttle valve.
Old 03-22-2009   #8
Slip the cable through the barrel nut than slip the spring on. Than turn the throttle on the carb by hand and the cable should slip into the groove in the swievel.
Hey weed is your carb like the carb in the pic above?
Old 03-24-2009   #9
no its not .were the needle, trottel valve and spring go there is no hole were i could put all 3 items in. its just a 3 t0 4 inch long slim metal tube with a black rubber around the whole tube and i dont know how to put the the throttel cable in the carb. does it need the spring and needle.
Old 03-25-2009   #10
hey weed did u buy the welbro carb and what bike did u buy it for
Old 03-27-2009   #11
it is a mini quad cobra s4 i brought a hp caburater
Old 03-28-2009   #12
ok weed u bought a totally diferent carb than i did,mine is for a cateyes pocket bike, even though u dont need to use a needle or spring for the hp carbs just hook up the throttle cable, u might have to adjust the carb after u hook it up but other than that have fun with the new found power it will produce and good luck with it
Page generated in 0.26354 seconds with 50 queries
