Originally Posted by StrayDawg63 I'm alittle amazed you didn't need some help getting your stock clutch off. Which tells me you can handle just about all mods throw at you which is a good thing.
So did you loose any of the top speed switching to the 14 tooth front sprocket? Or was it so small that you didn't notice because you got there faster?
Well you pretty much have all the bolt on's other than a Fatty pipe or Boost Bottle. You can either lightening your aluminum clutch or go with the heavier spring. Do you have a dremal that you can port match the end of the exhaust and gasket to your exhaust port. Or you could do away with the choke in your 603 and get a choke plate to open up the carb and let it breath in more air. You can lower your squish by removing the base gasket and just use a copper RTV sealer or motoseal. If you really don't care about having lights and a electric starter you can remove the starter wingings that are behind the pull starter. I'm sure I'll think of a few more but here's some to think about anyways. |
haha well thanks stray, im very good at automechanics and cars are my life so im pretty good at this stuff, i do whole transmission swaps on my own.
but for the bike, its lke what u said its gets up there so much faster thats idk if i lost anything plus im running too much oil (25:1) so im sure thats killin it just a bit, next gallon will b 32:1 to try that.
yea im still looking at the getting the pipe and the boost bottle set-up. i actually read about lightening my clutch but i dont have or know anyone with a drill press though i do have a dremel with all the attachments. is the heavier spring going to b something worth it, cause it'll give me some more aceleration correct?
and what is the port matching for my exhaust and what will it do for my bike? is the port off the head larger then on the exhaust?
also what is the squish? and base gasket do u mean between the head and case? i also might remove the choke like u said casue i never use the thing.
yesterday i was actually thinking about removing all my electrical but kinda like the ability to have the lights n such but maybe ill change my mind.
