x7 Help needed
clutch upgrade? what to do
my bike wont accelerate
no fuel to carb, help!
No electric start on x7
110, 35mph! bs!
Old 08-30-2009   #1
X12 Low Power?
Hi everyone.
I have an X12 110cc that runs awesome.
Problem is it starts and runs with no battery great.
Lights horn blinkers all work fine.
When the battery is installed I still need to kick start it.
The electric starter does not work nor do the headlights horn or blinkers.
Once I kick start it everything works.
The battery has a full charge but the power light on the dash barely
lights. The blinker relay humms but the blinkers don't light.
I assume the headlights should come on with battery power
when it's not running.
Starter switch does nothing.
The fuse in the battery wire appears to be fine.
Anyone have any suggestions?
Pic of my scoot with a baby my wife sits for.
wingsboy is offline   Reply With Quote
Old 08-30-2009   #2
140ccX18's Avatar
Re: X12 Low Power?
your better off getting a new battery like a yuasa 12v...The stock batteries are crap.
140ccX18 is offline   Reply With Quote
Old 08-30-2009   #3
Re: X12 Low Power?
Thanks for the advice, but it is a new battery.
It's fully charged actually has 14v.
Old 11-15-2009   #4
Re: X12 Low Power?
When i first got my x12 (used but pretty much new) it wouldnt start. I hooked up another battery and it started right up. Just try a new battery is what i would recomend.
COWPIES2001 is offline   Reply With Quote
Old 11-15-2009   #5
SPB Mod Master
Re: X12 Low Power?
When its running the stator on the charging system delivers 50 watts of power to charge the battery and run the lighting.....If the lights dont come on with the keyswitch you have a bad keyswitch ,melted wiring , bad battery terminals or poor ground...The keyswitch can be tested by the digital multimeter or the bottom cap on the ignition switch can be popped off to inspect to see if the terminals are still soldered onto the tabs..The chinese solder jobs sux..........Peace
Page generated in 0.18883 seconds with 29 queries
