Here's a picture of the B1 rep I brought about a month ago.
She had a number of problems wen i first got her, but aesthetically looks pretty good.
The ignition lead was a little loose at both ends which was causing it to miss and splutter at high revs. I replaced the lead with a fatter HT cable and the plug cap with one that clips onto the plug properly. Problem solved.
Next problem is it overheats after about 10 minutes. I suspect the ghey belt drive may have been slipping, and after removing the flywheel I found by spinning the water pump with my finger the bearings were pretty nasty.
So Saturday night I split the crankcase. The water pump seal had failed and the bearings were full of water.
I am about to place an order at Ozminimoto for a Blata water pump, belt, drive gear, seals, spacers, shims and a new flywheel. Bearings I can source locally. I will also get new crank seals and bearings to replace the old cag ones. The cag crank can go back in for now.
An online PDF part list for an original Blata B1 Origami can be found
here.
I placed an order at Pannons nearly a week ago for a bunch of stuff.
PHBG 19 DS
Manifold
Stuffer
Carbon fiber reeds
Gaskets
Top end bearing
25H chain breaker
Blata racing clutch
Coolant bottle
This week we are ordering from xminimoto,
Big bore kit
Performance exhaust
CNC machined head with high compression dome
This month is going to be like Christmas.
I wasn't looking forward to undoing the flywheel or clutch nuts. While I was at the tool shop last week I noticed this we sucker on special.
So I decided I needed it. Haha the flywheel nut didn't stand a chance.
We made a flywheel puller from a chunky piece of steel with two holes drilled in it that line up with the two threaded holes in the flywheel.
I also picked up a tyre gauge and made up a connection for the nitrogen bottle so I can pump up tyres and use the rattle gun portably.
And every workshop needs a set of socket tee handles.
