Go Back   Pocket Bike Forum - Mini Bikes > General Pocketbike Forums > TOOL TALK
Dremel....the most famous pocket bike tool
Tuning Stand
best tools
Manual
CDI Connector
electric impacts from matco
tools that should be added
x7 Bullet Brighter Headlights?
Rear sprocket upgrade?
The merits of having an air- compressor.
Old 09-30-2009   #1
chinese wiring!?!
does anybody know how to connect the wiring to these lifan engines?
im just using a cdi and kill switch, no lights, no speedo, no battery....
i hope someone can help cause i dont want to fry my cdi or generator
leirhiht is offline   Reply With Quote
Old 09-30-2009   #2
SPB Mod Master
Re: chinese wiring!?!
Heres a diagram that will get you running........Peace
Old 09-30-2009   #3
NICE! THANKS MAN. i failed to mention that the motor is a 86cc. is there a difference in the wiring? i am almost positive that it is the same.....
Old 10-01-2009   #4
SPB Mod Master
Itll be the same..........
Old 10-01-2009   #5
HEY cam2,
mind if i ask what that pic is of in the middle of the diag?
its a box with 6 squares and one square on the top with a X in the middle of one square?
Old 10-01-2009   #6
SPB Mod Master
Thats the backside of the CDI plug and the box with the "X" is left open without any wire..
Old 10-02-2009   #7
NOW im confused, i thought the cdi plugged into the pig tail attached to the motor. i tried calling the ppl i bought it from but i cant understand them.
i wish i could show u pictures some how...
Old 2 Weeks Ago   #8
Doc Loveless's Avatar
the thing with the x is the male molex connector that fits in the cdi
the b/w and b/r comes from the motor to the male molex
best thing is to follow the colors and try to think as simply as possible. i just made a harness for my lifan from scratch and i found myself thinking too much too often
Doc Loveless is offline   Reply With Quote
Old 2 Weeks Ago   #9
SPB Mod Master
Take pictures and post them on the site through photobucket............Peace
Old 2 Weeks Ago   #10
SPB Mod Master
The diagram I made is a direct connect racing type harness and it eliminates all those troublesome chinese plugs except for the one that plugs into the CDI box........You can still use them if you want.The colors of the wires are accurate with the harness colors of your electrical system...The remaining solid yellow and solid white wires coming from the stator go to the regulator/rectifier for the charging system.....as Doc stated you only need the black/red and the blue/white coming from the stator going to the cdi to run the bike.The CDI powers the coil and also has a circuit for the killswitch when grounded...............Peace
Page generated in 0.29558 seconds with 45 queries
