| Re: fiberglass or carbon fiber? Pretty much, you take the old stock tin reed, and cut it to resemble the top reed on a Black Widow set. (I used tinsnips to cut mine.) You then take that reed, and layer it over the top of your carbon fiber reed.
Assembly would be:
-reed stop
-modified reed
-CF reed
-reed block
All you're doing is installing a second reed over the top of the first one, but the top one is modified. Smooths out the powerband, and virtually eliminates top end reed flutter.
If you go to the air-cooled section, and look for davation's cheap triple stage reed mod, you'll find it in the mods section. If that doesn't work, do an advanced search, and look for threads started by davation. |
