Go Back   Pocket Bike Forum - Mini Bikes > General Pocketbike Forums > TOOL TALK
Dremel....the most famous pocket bike tool
Tuning Stand
best tools
x7 Bullet Brighter Headlights?
Manual
adjustable wrenches
CDI Connector
electric impacts from matco
Compression Tester
tools that should be added
Old 07-02-2009   #1
Exclamation HELP! Lights flickering!!!
Well I broke in my x7 bike with all electrics working but all lights flicker to the beat of the exhaust. I also added 7 sets of led lights of blue underglow that flickers the same as all stock lights. Do I need a bigger fuse or how could this be fixed?
Djsurfer616 is offline   Reply With Quote
Old 07-02-2009   #2
PBP Administrator
nick's Avatar
Re: HELP! Lights flickering!!!
Does it happen all the time? How full is the charge on your battery? And does it do the same if you turn it on while it is plugged in to the wall? that last step will help to tell if it's an undercurrent problem.
Nick.
nick is offline   Reply With Quote
Old 07-02-2009   #3
Yea it happens when i turn on the bike, they never turn off but they dim to the beat of the exhaust. I dunno I havent ran it no more than a few tanks since first break in so its pretty much brand new. Plug in to the wall? How can you plug in the bike's electrical to a house hold electric socket?
Old 07-02-2009   #4
PBP Administrator
nick's Avatar
It didn't come with a Wall Charger for the battery?
All the Mid-bikes I have came with one, If you have one and plug it in while testing the lights you should notice a difference if it's a problem with the battery.
Nick.
Old 07-02-2009   #5
Wel i am almost 100 percent sure this x7 bullet does not come with a wall cherger, or at least failed to find it.... can someone tell me where its located i took the bike apart.
NOW the bike wont even start. All i did since the last time it started was add a fliter and a new exhaust and now it cranks but doesnt ever turn on...
Old 07-02-2009   #6
PBP Administrator
nick's Avatar
Look to the fuel supply, The exhaust won't be what is causing the problem.
Pull the fuel line off the carb and make sure it can flow freely through the line/filter.
The charger is external, it plug's in close to where the key goes, But you might not have one.
Nick.
Old 07-02-2009   #7
Yea it aint the exhaust...pulled it out and gas flows out fuel line freely. Still wont start....
BTW, thanks for all the help nick
Old 07-02-2009   #8
PBP Administrator
nick's Avatar
It's never a problem.
Next thing you could check is the "Float Bowl" (Very bottom of the carb) to make sure it's filling with fuel.
Nick.
Old 07-03-2009   #9
Yes thats also pumping in fuel perfectly. The bike has only been ridden twice.
Page generated in 0.30444 seconds with 41 queries
