Go Back   Pocket Bike Forum - Mini Bikes > General Pocketbike Forums > TOOL TALK
Dremel....the most famous pocket bike tool
Tuning Stand
best tools
x7 Bullet Brighter Headlights?
Manual
adjustable wrenches
CDI Connector
electric impacts from matco
Compression Tester
tools that should be added
Old 02-22-2009   #1
Pegdrag's Avatar
Cool The merits of having an air- compressor.
Exactly that, this thread is to discuss the variety of air-compressors, air tools and their multiple uses & applications, as well as techniques of use.
To start, the noisey air squeezer itself, what size do I need? How much are they? How many CFM's do I require, how many does this one put out, what's a CFM?
Hopefully this thread will answer these questions and many more.
Take mine for example, it's a Coleman (usa), 5 HP, oil-less (with a 3 petal metal intake reed), 27 gallon tank, 130 psi max. output, and runs one or two 90 CFM (cubic feet per minute) consuming air tools without a problem of over use and over heating. And works great with the hand plasma-cutter.
Oil-less means that the motor and comp. are more or less one piece, and make a higher pitch whinning sound. The other is a two piece system, where the motor (elec. & gas) and the comp. are separate, joined buy a belt & pulleys, and make a bop, bop, bop, bop, bop....., sound. The comp. crankcase has oil in it for lub. This is the more common one.
Some comp. are vertical, some horizontal. They come in all sizes and prices. If all your going to do is air brush art you'll not need a big system, and the same goes for the heavier duty needs. Big job, big air.
I'd be lost without my air-comp. It would render all those wild air tools redundant.
Old 02-22-2009   #2
Maico Shark's Avatar
Re: The merits of having an air- compressor.
What you did say is CFM stands for cubic feet per minute air output. But why is that important? Most air tools will have a recommended CFM requirement. If you have a decent size tank you can use your air tools trackside for a limited amount of work. The air jet attachment is useful for blowing out carb jets and other areas that need cleaning. Also a 27 gal tank as Pegdrag has will inflate at least a dozen flat tires without needing to plug it in to recharge.
Maico Shark is offline   Reply With Quote
Old 02-23-2009   #3
Pegdrag's Avatar
Having the proper CFM tools rated for your compressors output means that it won't run on and on, because if the tool requires too much CFM's to run, then the comp. keeps running to keep up with the air used, especialy when the storage tank is small. The bigger the tank is the less your comp. will come on, however it takes a longer time to fill a big tank. So again you'll have to balance budget, needs, knowledge, and CFM requirements.
At the track it's a hard time without an air-compressor or a least an air-pig(portable air tank only), and when you've got one, it seems your very popular.
Old 02-23-2009   #4
Stu
CFM output is definitely important, in the past I've had to stop working on something and let the compressor recharge because the tools I was using used too much air for the compressor to keep up.
On the other hand I have an air compressor that I never used so I don't know if it even works anymore. It was basically a six cylinder radial engine that was converted to a compressor, three cylinders ran the engine and the other three were the compressor. It only put out 90PSI but it would supply that to three jackhammers all day.
Stu is offline   Reply With Quote
Old 02-23-2009   #5
Pegdrag's Avatar
That sounds like a wild set up. 90 psi, and I'll bet the CFM is up at 240-250.
And that's exactly what the CFM's thing is all about. Air volume.
Old 02-23-2009   #6
Stu
Yeah, it is kind of wild I'll see if I can get a pic of it. It really wasn't practical for us to use as it was noisy, used a fair amount of gas, and put out way too much volume for us to ever use.
Old 02-24-2009   #7
Stu
Here's a few of pics of that compressor.
Old 02-24-2009   #8
cagaroni's Avatar
harbor freight is your friend
Old 02-25-2009   #9
Pegdrag's Avatar
Holy cow, thats gotta be the ugliest squezzer I've ever seen. It's wicked. And it runs too eh.
Is it off an old airplane? (primative transport device). And for sure home-made. Yeah Man, that's quite the relic. Got any history on it?
Old 02-26-2009   #10
Stu
It's actually not home made, they were at one time available for sale. All that I can tell you is that this one was once owned buy the Southern Pacific railroad. My uncle worked for SP and when they were going to dispose of it he took it home instead, and when he decided to get rid of it we took it. It's been so many years since we used it I don't know if it still runs but it does still turn so I assume that with a little work it would probably run again.
Page generated in 0.71304 seconds with 289 queries
