Go Back   Pocket Bike Forum - Mini Bikes > General Pocketbike Forums > TOOL TALK
Dremel....the most famous pocket bike tool
Tuning Stand
best tools
x7 Bullet Brighter Headlights?
Manual
adjustable wrenches
CDI Connector
electric impacts from matco
Compression Tester
tools that should be added
Old 02-21-2009   #1
PBP Administrator
nick's Avatar
Here is a list of some tools that should be added to here...
I would attach photos but my quota is full, and nobody answered my request for some type of help, so sorry!
#1 3-show pulley puller, for removing the flywheel and clutch.
#2 Calipers either digital, Dial, or vernier, for measuring Squish, or the Inside or outside diameter or depth of just about any piece that isn't longer than the calipers.
those two pretty much have to be added.
something that should be added but is not really understandable to most novices..
#3 Dial Indicator, for me this is key while checking for radial and lateral runout of tires and wheels.
for any who cares,
radial and lateral runout cause tire thump, or waddle, and will cause a rough ride and accelerated tire tread wear, and can also lead to conicity.
there are so many other key tools, but I don't want to spoil all the fun, I'm sure you guys will get em all...
Old 02-21-2009   #2
Hooligan
SpyGuy's Avatar
Re: tools that should be added
-Good set of Allen wrenches/Allen socket set
-Good set of metric open-end/box-end wrenches (may need to double up on several sizes)
-Metric socket set, preferably star (12-point) sockets if you can get them
-Several screwdrivers of varying sizes
-Pliers: regular, channel lock, needlenose, vise-grips
-Crescent 9adjustable) wrench
-Spark plug wrench
-Rachet wrench
-Mini-rachet wrench (Sears sells a good one that is 1/4" on one side, and has a fitting for a screwdriver bit on the other - very useful for 90* angles, such as your air cleaner)
Old 02-24-2009   #3
TxMiniGP Racer #5
FiveStarSky's Avatar
cheap tools, like zip-ties and JB weld. They can do wonders.
FiveStarSky is offline   Reply With Quote
Old 02-25-2009   #4
Pegdrag's Avatar
And for sure some krazy glue(to piece the plastic back together before you fiberglass it). Can be done at track with minimal problem.
Some 2 part epoxy and some gas-proof silicone(heat resistant), but above all, you gotta have some of the handy-mans secret weapon, duct-tape. lol. Don't leave home without it!
Old 02-25-2009   #5
Pegdrag's Avatar
And yes nickj, tools to me are like Pokemon cards to kids...gotta get'm all.
Old 02-25-2009   #6
cagaroni's Avatar
bore light - good for looking down ports and hard to reach places
torque wrench - so as not to strip bolts
drill press - for drilling things
digital gram scale - good for weighing stuff like.. errr.. pistons
Old 02-25-2009   #7
Pegdrag's Avatar
Cag, U Scag.
When you say bore light, do you mean one of those flexy long neck, light at the end of it thingma'jiggers? Cause yeah, they're handy all round. Use them at work to check die cutting clearances.
It's a gotta have it tool, for sure.
A 3/8 torque wrench?
And for the purpose of weight reduction watching (as your drilling and grinding and machining different odds and ends of this and that) a scale would come in handy, especially for match ups.
Old 02-25-2009   #8
cagaroni's Avatar
those flexi lights are good too... i was referring to a bore light that people use to look down gun barrels.. basically it's a mini flashlight with a curved glass cylindrical endcap that u stick down the barrel.
Old 02-25-2009   #9
Pegdrag's Avatar
Ooohh, cool. I guess I'd find one at the local gun shop then eh?
The light comes out the end like a fiber optic, no?
Old 02-25-2009   #10
Hooligan
SpyGuy's Avatar
And they don't even need to check your ID if you get one! (Only their OTHER toys ........)
Page generated in 0.23065 seconds with 45 queries
