Advance porting basics
Closed Thread
Old 06-21-2006   #1
Brake tuning for cateye
It may not seem like it but one of the most important parts of your cateye is brakes. Ok starting off you need...
A 5mm alan wrench .
Yes thats all you need actually. So on to the fun part. When looking at your rear brake you see your brake cable. Its attached to a black looking arm. Using the alan wrench loosen that bolt that is on the black arm 3/4 way and then pull the arm as much as you can clockwise. Then hold the cable that comes out of the arm. While doing that pull the arm counter clockwise, depending on how powerfull you want your brake, turn the arm to the left more for more braking power. And right for less power. Now you dont want too much power for your brakes. Once arm is set to your way tighten the bolt with your 5mm as much as possible.
I reccomend for tuning brakes to do a 8-0mph test so you dont go over your handle bars incase you tune them too high. Also you tune the front the same as the back.
Fastspoolsupra is offline
Closed Thread
Brake problem stlshotcaller23 4Stroke Midbikes 2 05-13-2006 11:41 AM
X7 brake and throttle questions.. searched with no luck. Michael_K 2Stroke Midbikes 6 10-16-2005 07:21 PM
hydraulic brake bleeding keiththapocketbikekid 4Stroke Midbikes 22 07-20-2005 05:13 PM
Just got B1 and rear brake light not working? HELP!! kbm 4Stroke Midbikes 1 06-17-2005 10:12 PM
X7 Brake Problem....... X-7-NOOBLET 2Stroke Midbikes 4 12-13-2004 04:05 PM
Page generated in 0.16213 seconds with 19 queries
