this is for the members who PMed me recently asking for this diagram, so i'll go ahead and post it up rather than PM it so that future members can check for this diagram when searching.
if you have trouble viewing it, let me know because i have a higher-res version of the image.
thanks for the diagram , i spent endless hours searching for this worldwide and no one seemed to have it THANKS SO MUCH !!!
hey thinks for the diagram ........but does anyone KNOW about the Little black box that is under the SEAT it is THE CONTROL MODULE ....if this is malfunctioning can this prevent the Electric start from working all i get is a CLIKing Sound .....and help.......and also it will start with the pull rope.....how can i tweak it to go faster than 20mph any INFORMATION ON HOW TO TUNE UP 49cc would help thanks all.
your not going to be able to go past 20 mph without purchasing some better parts i.e. exhaust, air filter, etc.. but yeah if you have seperate questions i would reccomend starting your own topic otherwise youll mess up the flow of this topic making you seem like a noob and an obsturction
would like to bypass lights etc.. just want to run motor only. I got a cateye from a friend but wasn't working. replaced cylinder, piston, battery, plug, but still no luck starting?
Good talking to you on the phone today, glad you are getting the help you need with your bike.
hi im sam im having the hadst time getting a print for the electrical if you have one please e maile it to me please to sam1rivera@yahoo.com god bless you again meny thanks sam
can someone please help i beleave i have a 49cc cat eye and it was running at first then it stopped so we checked it out and ended up takin the whole thing apart to costomize it.
so very long story short the wiring is jacked anyone have a diagram
if so please e mail me at twofastfer@yahoo.com
thank you
Good thread. Maybe someone can enlighten me a little. I have a cateye with no wiring at all. I have just the bike and the motor. how can I run a kill switch without having the cdi box or control module? Also, the engine still has the electric start wiring, how do I wire that up to work? I do have the battery still, which I will probably need. Thanks.
im interested inputting the electric start back on mine aswell. just a frame and motor. still has electric start box under the pullstart... do i just need a 12v feed to it?
I have a black 16-18 gauge wire and a red 16-18 gauge wire that are connected separately to the coil, and they come off the coil and are just hanging off the engine. If I connect those to the starter button, that would be my kill switch? When I bought the engine, they said it had electric start on it, but I don't have any wires coming off the pull string cover area. I don't really care about the electric start. I just need the kill switch.
I have a cat eye 49cc the black box under the seat is called charger controller from my wire diagram manual, the thing is I need a new one but cant find one with 4 wire only 3 wire. If you now of any animal like it. or if there is a way for me to us a 3 wire one would help.
