Advance porting basics
Old 09-18-2004   #21
is there anywhere to buy one of the new CVT drives for a cateyes and x1?? what is the web site for r-sports?? thanks
kuzikan is offline   Reply With Quote
Old 09-18-2004   #22
www.extreme4strokes.com
Not a PBP Advertiser.
Old 09-18-2004   #23
Nameless's Avatar
I got a inch shorter belt..that seems to help also...I needed it becauses I also sandblasted my pullies for more grip..Easy mods..Bang for the buck..
Nameless is offline   Reply With Quote
Old 09-18-2004   #24
well from what i have seem and been told that site is down right now. does r-sport sell CVT drives??
Old 09-19-2004   #25
If you want just the CVT tranny, you can go to www.scooterparts4less.com.
Its about $80.
pentaX is offline   Reply With Quote
Old 09-19-2004   #26
where do you get an inch shorter belt? I just did this mod yesterday but didn't really get to test it out yet. has anyone tried it yet? Actually I test drove it a little bit. Couldn't really tell a huge difference except for the motor reving up higher? it seems to be a little unstable on WOT? Is it supposed to be like that? Also I tried taking out all of the weights and it seemed like the belt was totally slipping and barely moving the bike while revving up really high.
SLEPT-ON is offline   Reply With Quote
Old 09-19-2004   #27
If you remove ALL of the weights, then there is nothing to PUSH the pullies closer together and it will slip constantly.
Pops Racer is offline   Reply With Quote
Old 09-20-2004   #28
Nameless's Avatar
i got my belts here
http://zacm.com/belt/index.htm 18"er 19" is stock
Old 09-20-2004   #29
Guys;
Ok, I tested the CVT mod on my X2 today.
I had recently changed the rear sprocket from a 44T to a 54T and saw gains BOTH in accelleration and top speed.
With the flyweight mod (CVT) the acceleration was slightly better (very slight), but top speed was way down. About 7-8 mph (on the speedo).
It is my guess that when using 3 rollers instead of 4, there isn't enough total centrifical weight to fully compress the front pulley and achieve maximum overdrive. At least in my case.
Pops
Old 09-20-2004   #30
CVT Belt
Guys;
Just wanted to add since I had the CVT case off, the numbers on my belt are: 13 x 425Li.
Mine also fits very snug between the pulleys at rest and this is the way it should be.
Pops
Old 09-20-2004   #31
RS1
just install a Comet CVT!
RS1 is offline   Reply With Quote
Old 09-21-2004   #32
did the mod last night....
Got it all done last night. I was putting in a rocket key and did the cvt mod while I was at it. All I know is that my bike is alot better off. It is quick off the line and now do 35 on the pos speedo where before I could only get 20 out of it.
I noticed that my belt was really snug and was difficult to get back on.
gon4lo is offline   Reply With Quote
Old 09-21-2004   #33
Pops racer:
Isn't it true that a larger sprocket will give you better bottom and and a weaker top end? i did this mod with the stock sprocket and it added almost 5 more mph to my top speed. Belt slippage is more though! gonna get that 18"er!
Old 09-21-2004   #34
is it possible to install a comet cvt without rewelding? And is it better in the first place?
Old 09-21-2004   #35
Nameless:
What category do I look under? 1/2"
3/8"
5/8"? WHat's the exact part #?
Old 09-21-2004   #36
Pops racer:
Actually if the engine does not have enough HP to pull that gearing, then top speed will be less. Gearing is only part of the equation, you need power too.
In the case of the X2 (X1-CVT), the stock rear sprocket seems to be a little on the small side and gains are being made with a larger rear sprocket.
Pops.
Old 09-21-2004   #37
KennyK's Avatar
Just a tip on those sandblasting their pulley's. I have raced snowmobiles since I was three years old. I have a glass beader and sand blaster in my shop. Never once did I ever use them to scuff up my clutches. I use a brown scotch brite pad and it works great. I'm sure it would be more then adequate for a 5hp cvt motor.
KennyK is offline   Reply With Quote
Old 09-21-2004   #38
well that's wierd because every web site that sells x2/1 sprockets says that a smaller sprocket will give you better top end and a bigger sprocket gives you more torque or more off the line power?
Old 09-22-2004   #39
That is correct... Bigger (rear) will always work. Smaller will work, IF... Your motor has enough hp to pull the greater load imposed by a higher ratio gear.
A few teeth more or less on the rear as you require shouldn't hurt anything. Be aware that changing sprockets can require changing chain lengths too.
roomtemp is offline   Reply With Quote
Old 09-22-2004   #40
Club PBP Member
jman47cc's Avatar
i did the cvt mod yesterday, took it for a ride, and it does accelerate somewhat faster. However, there was no gain, maybe a very small loss, of top end.
How to:Free and cheap CVT mods and tuning bartw 2-Stroke Midbike How 2's 1 09-16-2004 04:59 PM
Page generated in 0.42950 seconds with 77 queries
