Advance porting basics
Old 09-14-2004   #1
www.extreme4strokes.com
I have read a lot of posts in here and no one seems to explain how to get your CVT to work to your advantage. The CVT is a good thing to have and if properly tuned will help a lot with takeoff and a higher top speed.
Free tip: Remove the CVT cover, buzz off the front varieter nut so that you can slide the pulleys off the shaft ( I say buzz off because if you do not use an impact you can strip or bend something by trying to hold it from rotating while wrenching or ratcheting) When you pull the varieter apart you will see that there are 6 grooves inside and 4 roller weights in there. Take out one of the weights and respace them evenly leaving only 3 back in, one weight one empty slot, one weight and one empty slot ... Reassemble and do not put the black cover back on the CVT, you will notice that now the engine screams before the front varieter allows the belt to ride up (shift) Your accelaration is now better and your top speed may have increased due to that your bike stays in the power range longer and doesn't upshift till it can actually pull the taller gear.
Under $20 mod: Same as the first mod but purchase some lighter weights from a moped performance shop, they are a standard moped size (there are some larger rollers but if the shop asks your bike takes the smaller more common ones) The stock weights weigh about 7.5 gr although I have seen a lot of variations so that is one reason why some X1s run better than others. You can get the aftermarket weights in .5 gram increments, 3gr, 3.5gr, 4 gr etc.. Now start trying different weights in there, you can use up the other grooves and install 6 weights in there that are lighter and get different results. Remember label your packages of weights because when you do mods to the motor you will increase the engine's rpm and may want to go to lighter weights to take advantage of the new power band.
It is also helpful to delay the shift of the rear spring, it seems like the stock X1 spring is very stiff and shifts about as late as you would want to but you can install shims in front of it to stiffen it up if you want to experiment.
When I modify mopeds we often install "overdrive varieters" basically the front pulley is designed so that it will allow the belt to ride up higher and give you more gear. I do not have the manufacturing capability for such a part but I am sure many of our aftermarket parts suppliers are reading this and maybe someone will put it in the works.
Let me know if this helped you and if you get good results
Old 09-14-2004   #2
This should also be placed in the FAQ section.......nice.
Old 09-14-2004   #3
someone figured out my secret. i must work faster now.
bigsugar500lbs is offline   Reply With Quote
Old 09-15-2004   #4
badbartlby's Avatar
Sweet mod man, I almost have wheelie pullin torque now. Thanx for the tip!!!
badbartlby is offline   Reply With Quote
Old 09-16-2004   #5
srwsr's Avatar
Hey, I'm considering trying a CVT bike, will this only help with the belt slippage or totally eliminate slipping. I'm about 255-260, and I've heard that there is no eliminating slippage for guys my size and acceleration will always be harder to achieve than top speed.
srwsr is offline   Reply With Quote
Old 09-16-2004   #6
YoGuB's Avatar
hey badbart, wich mod did you do? the free one or did u get different weights?
YoGuB is offline   Reply With Quote
Old 09-16-2004   #7
Slipping is enevitable. All belts will slip, especially how loose the CVT belt is.
I weigh about 265lbs, and my bike is very quick. It tops out a couple mph higher than stock. Currently, I have a rockey key, intake, wt-603 carb, and tuned pipe.
I did this mod last night, and resanded my pullies and threw a little belt dressing on the belt itself (not on the pulley..). I can see how removing the little weights will help, as they werent linear. Their placement hindered the rotation and I hope to gain decent results.
pentaX is offline   Reply With Quote
Old 09-16-2004   #8
Club PBP Member
jman47cc's Avatar
can you take out 2 of the weights? anyone know? Also, across the internet i see pocket bike shops selling a cvt mod, is this it? i see it ranging from 45 - 80$. thanks.
Old 09-16-2004   #9
Club PBP Member
jman47cc's Avatar
i took the cover off my cvt, and i have no idea of the weights you are talking about. I see nothing like that inside. Also, theres 2 bolts holding pullies, which gets taken off? it seems impossible to get either of them off.
Old 09-16-2004   #10
I second that... great info
roomtemp is offline   Reply With Quote
Old 09-16-2004   #11
YoGuB's Avatar
I'm going to try this today. Just taking out one of the weights. I'll keep you guys posted.
Old 09-16-2004   #12
Club PBP Member
jman47cc's Avatar
can you take a picture or a few of what you are doing, it would be an awsome guide for those less mechanically inclined.
Old 09-16-2004   #13
Club PBP Member
7star1stdan's Avatar
yes it would be nice if someone could post pictures of wht this mod looks like while they do it i have also looked inside my cvt and didnt see anything like that
7star1stdan is offline   Reply With Quote
Old 09-16-2004   #14
The weights are inside the front varieter. The weights push on the back plate of it to cause the belt to ride up on that front pulley giving you a higher gear, it is only one nut to take that thing apart so I would not consider this difficult. Lowering the weight of the rollers is like putting in a stiffer clutch spring somewhat, basically it will require higher RPMS before they work and shift the varieter into a higher gear so it gives you better take off, its like shifting your car at a low rpm or your motorcycle, you get better speed if you let the motor rev up and shift higher. THe nice thing about all the standard moped weights is that you can order them in .5 gram increments so as you do mods you can go to lighter weights when your power band moves up and that way your mods will make even more difference.
Old 09-16-2004   #15
Club PBP Member
jman47cc's Avatar
any ideas on how to hold the pully still? it seems every single bolt and screw on this bike is a sinch, but this one does not want to move.
Old 09-16-2004   #16
you have to use an impact wrench (electric or air) to remove the nut. there isn't any good method to brace the variator to use a conventional wrench or socket.
in about a month there will be a new performance website opening that will have CVT kits available, along with other real performance products that will provide more than marginal gains. and of course they will be an advertiser on PBP.
stay tuned...
Old 09-16-2004   #17
badbartlby's Avatar
Hey guy's just a little more input. First, for the not so mechanically inclined (sorry no pics) but you want to take the pulley that is bolted to the crankshaft off and it does take an impact wrench. Behind that pulley on the motor side you will see four small roller weights. Take one out and space evenly, wham way more torque. Second if you only leave 2 weights you will have serious torque until you run out of rrrr's no top end at all. Just my results yours my be different. good luck
Old 09-17-2004   #18
what about the cover
Can you put the cvt cover back on after this mod? My kid rides mine from time to time and I do not want him to get caught up in it.
gon4lo is offline   Reply With Quote
Old 09-17-2004   #19
RS1
Not a PBP Advertiser.
RS1 is offline   Reply With Quote
Old 09-17-2004   #20
The cover should go back on, just leave it off for when you are tuning so you can actually see when it shifts.
How to:Free and cheap CVT mods and tuning bartw 2-Stroke Midbike How 2's 1 09-16-2004 04:59 PM
Page generated in 0.33970 seconds with 77 queries
