Advance porting basics
Old 03-23-2008   #21
jbusa8's Avatar
Re: How To: Uninstall X7 R1 Governors (Pic)
ouch! my battery is NEVER fully charged so mine is crap too. the magic button works when its warm but oh well.
jbusa8 is offline   Reply With Quote
Old 03-23-2008   #22
Crazyj15692's Avatar
Yeah it must be fun using the electric start but I think it's easier not having to charge it all the time.
Old 03-24-2008   #23
jbusa8's Avatar
i prefer pulling it...its much more reliable
Old 06-27-2008   #24
Originally Posted by krazyqban View Post
There are two governors on the x7 R1 pocketbike. One is located in the hand throttle and the other is on the top of the carburetor. You will need a phillips screwdriver and an allen wrench. To uninstall the hand throttle governor unscrew the two large screws on the top of it. Take it apart and you will see a black, half circle, plastic piece, remove that piece and screw the hand throttle back together. To uninstall the governor on the top of the carburetor unscrew the bottom screw of the small L shaped piece. Once youve taken that off remove that screw and screw it back in without the L shaped piece. Removing these governors will allow you to go alot faster because your engine will rev at higher rpms. I hope this Helps if you have any questions send me a PM and I will try to answer them.
If i take both the throttle and the carb governor out, will it increase my speed more than if i just took one out?
smileyboy489 is offline   Reply With Quote
Old 07-24-2008   #25
Thanks for this thread man, now I just need to find an x7 bike. I want one.
kunal_rungta is offline   Reply With Quote
Old 11-09-2008   #26
salke X-7 racer's Avatar
can u post a pic of what the govenor ontop of the carb looks like so i o what to do? N what does the govoner on crb look like.?
salke X-7 racer is offline   Reply With Quote
Old 11-09-2008   #27
what does the govenor ontop of carb look like?
Old 11-09-2008   #28
StrayDawg63's Avatar
If you go to post #1 of this thread you will see the pic of it. It's the little L-bracket with the small screw in it.
Old 11-09-2008   #29
Where is the govener exactly on the carb??
Old 11-13-2008   #30
If it's there you would see it without any problems. It would be right on top of the carb. The little screw acts as a throttle stop.
Old 02-11-2009   #31
49cc X7/FS529 new Cateye pocket bike parts
The carb on this site has a stock and performance one. I have a X7 2 stroke and have stock carb and the only thing i see like the half moon and L shape is all the black plastic on the of the carb.
Jssraz is offline   Reply With Quote
Old 05-24-2009   #32
demo401's Avatar
Originally Posted by soaponarope View Post
hi i just paid for a x7 engine and its missing all the wires, i have looked for weeks for the wires i need. IF ANYONE CAN TELL ME WHAT WIRES I NEED, OR TAKE A PIC OF THEIR X7 AND ALL THE WIRES WITH DETAIL SEND IT TO..WASTEDEFFORTS325@HOTMAIL.COM AND I WILL PAY THE FIRST PERSON 5$ PAYPAL IF IT REALLY HELPS ME OUT ILL PAY 10$!
wrong thread dude. ur gonna have 2 search the thread. go to yellow search box and search for the thread u want
demo401 is offline   Reply With Quote
Old 06-16-2009   #33
Before you start pulling/cutting parts off your bike, take the air filter off and look at the throttle butterfly inside the carb. The throttle butterfly is what moves when you twist the throttle. Go ahead and give your throttle a twist did you see the butterfly open? Now think of twisting the throttle to open the butterfly as climbing a hill. You want to get to the top of the hill and be at the highest point possible without going too far. Same thing with your throttle butterfly. You want your carb to flow as much as possible by opening the butterfly to it's optimal position which should be 90 degrees from it's closed position. If you twist your throttle and it opens the butterfly to where it needs to be then removing any components is going to screw you up (you will go to the other side of the hill and miss the peak). If you aren't opening the throttle butterfly enough, then by all means, fricken cut off that stopper.
AllTorque is offline   Reply With Quote
Old 07-29-2009   #34
i have an x7 bullet that im working on i need help what kind of carb intake to i need to install a walbro hp carb????/
CoreyMagnuz314 is offline   Reply With Quote
Old 08-19-2009   #35
hey if i take off the little screw that accelarte the pocket bike if i take that off the bike won't stay on right?????
x1 pocket bike is offline   Reply With Quote
Old 12-30-2009   #36
Originally Posted by jbusa8 View Post
thats an awesome idea! pull start! haha elecric start is *** anyways
lol my X2 electric start never worked when i 1st got it...... the crapy stock battery (5ah) didnt hold its charge...... so i upgraded it to a 7ah..... it always works now
TheBestGuyInTheWorld is offline   Reply With Quote
looking for a X7 R1 Mirakle Chat 3 03-01-2008 11:30 AM
X7????? tbates1277 2Stroke Midbikes 15 12-09-2006 07:12 PM
WTB: x7 r1 replica WantAR1 Pocketbikes Wanted 0 01-19-2005 09:26 PM
Want your R1 / X7 / 380x bike to appear on the DDM website? davesmotors.com 2Stroke Midbikes 11 01-16-2005 07:56 PM
Return of the Clones...X7, GS R1, 380 whatever genesisautoworks 2Stroke Midbikes 67 10-29-2004 11:16 AM
Page generated in 0.33760 seconds with 64 queries
