Go Back   Pocket Bike Forum - Mini Bikes > Support Area > 2010 CALENDAR CONTEST
The Ultimate Pocketbike!
The Dirty Girl
BlueSi4's Meanie
icebreaker!
From Rags to Riches!
Rising Sun Ninja
Tasmanian Devil
My Rides
- DiiCii*
my One and only
Closed Thread
Old 07-16-2009   #1
swheels's Avatar
The Dirty Girl
Where to begin......I had my bike for alittle over 4yrs.All i ever did was race it.Wether it be in a lot or a track.The bike was built to do only one thing and that' to be raced.
It has come along ways from being stock,so the bike has evolved many times over from suspension to motor to light chassis mods.
I named my bike the dirty girl because every time i would lube up the chain.Then i'd go for alittle test run.The chain lube would get slung all over the place and with the slicks picking up the little debris, it would stick to the chassis and things.Plus some of the war scares she aquired over the years.LOL The bike is an x18.
The mod list includes:
1.yx 150cc base.
2.Nology coil.
3.Nology fire wire.
4.a big bore kit
5.TB v2 roller rocker head.(ported and polished)
6.28mm mikuni flatslide pumper carb.(This carb has a spray nozzle that sprays the fuel)Not as radical as my 28mm FCR down draft.But i got the motor tuned in easier with the Mikuni.LOL
7.A Dr.Frankenstien big bore custom underslung exhaust.
8.Tb oil cooler and braided lines.
9.custom dual front disc brakes.(with larger x18 rear rotors up front for the larger discs)
10.A custom front fork brace.It actually serves 2 purposes.(i made the brace recently so not seen i these pics)
11.Fully modded stock forks includes:spring preload adusters(custom made),modded damper rods internals,with bound and rebound adjustments.So now i have total control over the front fork action.This i am most proud of.
12.A custom made rear shock that has bound and rebound adjustments as well as spring preload.(I made this rear shock using 2 shocks from 2 different manufactures)
13.Front slick (soft compound)
14.rear slick (medium compound)
15.x1/x2 triples trees and bar clamps. I decided to go with this setup because with the x1/x2 triples being wider than the stock triples.Allowed me to use rims with wider hubs or use bigger brake calipers and rotors.The bar clamp from the x1/x2's seem to clamp better than the stocker.Plus the moved the bars foreward about an 1/2in.They also allow the bars to be moved out or closer in.So you can really make the bike more comfortable to your liking.
OH almost forgot.16. modded x7 foot peg brackets.
17.x7 fairings.
18.Slight chassis mods.
19.steering dampener.
20.Vapor trail tech digital speedo/rpm gauge/temp guage.
swheels is offline
Old 07-16-2009   #2
swheels's Avatar
Re: The Dirty Girl
I gotta takes some better pics.These will not work for me.LOL
swheels is offline
Old 07-16-2009   #3
PBP Administrator
nick's Avatar
Re: The Dirty Girl
Clean that sucker! I gotta say I LOVE it, I bet it hauls some major butt.
hah I just noticed, Dirty girl, maybe she likes to be dirty.
Nick.
nick is offline
Old 07-16-2009   #4
Hooligan
SpyGuy's Avatar
Re: The Dirty Girl
Well, at least he doesn't have a pinup on the tank doing something naughty ...... although he may after reading this post.
That's some serious modding, swheels. Good job!
SpyGuy is offline
Old 07-17-2009   #5
swheels's Avatar
Re: The Dirty Girl
Nick.
Hey thanks
funny thing to i'm alittle superstitious about cleaning the bike to much.But yet i'll tinker with the carb and things when it's running great just to see if i can get alittle more out of her.LOL But i refuse to do a thorough cleaning.
Thanks...
Naw i won't do that i got 2 daughters 7 and 8yrs old.Sooo otherwise they would tell momma.
I did have a saying about the bike: She's a lady in the streets but a real b**ch on the tracks.LOL
swheels is offline
Old 07-17-2009   #6
Hooligan
SpyGuy's Avatar
Re: The Dirty Girl
. o O (Boy needs those "devil and angel" stickers from the auto parts store .....)
SpyGuy is offline
Old 07-17-2009   #7
swheels's Avatar
Re: The Dirty Girl
Here's some older pics. I'm tryin to hold off on any new pics because of the brace mod.Hopefully if everything goes well there's a race coming up in oct.So i'm trying to keep it under wraps until then.
swheels is offline
Old 07-18-2009   #8
Kevin
K-Pac's Avatar
Re: The Dirty Girl
Swheels I just realized your bike is like the hybrid x bike. Its got x1, x2, x7, and x18 ! Very cool bike and finally a mid on the contest!
K-Pac is offline
Old 07-18-2009   #9
swheels's Avatar
Re: The Dirty Girl
LOL yep oh and there's a cag pocketbike triple tree in there also and some mountain bike parts too.No joke! I recently took of the thermos exhaust also.Well you can see it in the much older pic.LOL
swheels is offline
Old 07-19-2009   #10
Hooligan
SpyGuy's Avatar
Re: The Dirty Girl
Dayum, dude ..... that's one big exhaust can. Cool wheels, you did a nice job combining everything to make it work.
SpyGuy is offline
Old 07-19-2009   #11
swheels's Avatar
Re: The Dirty Girl
Thanks if your talking about the thermos.It's actually way smaller than the stock x18 exhuast.
swheels is offline
Old 07-29-2009   #12
swheels's Avatar
Re: The Dirty Girl
Well i guess i can add the uni link rear suspension mod to the list.I really like it and it gives me much much much more tune-ability out of the rear shock.Now this setup allows me to raise and lower the rear of the bike 2ways.Plus now i can run a shock from 5'' on up to 9''.The biggest factor is i can run so many different spring rates it's crazy.Anybody on an xbike knows that you reeeeeaaallly can't venture far from the 1500lbs spring rate,especially if your racing road course on one of these bikes. Right now i'm using a 450lbs rated spring.On a stock setup,that wouldn't even be enough to hold the bike up under it's own weight.Not to even think if somebody was sitting on it.
It's a installed on the bike already.But heres i quick pic to give an idea.
Hey i don't really have to keep adding mods that i do to the list do i???? Cause i always doing something.
swheels is offline
Old 07-30-2009   #13
Re: The Dirty Girl
lookin good dirty girl, whaddya say i go round that azz next race? lol
rip thermos
they are never done S
Blitz$M.Inc.$ is offline
Old 07-31-2009   #14
swheels's Avatar
Re: The Dirty Girl
rip thermos
Well you can try.LOL But i gotta tell ya she feels like a totally different bike. Now it seems like i don't have enough power to get the bike out of line.I'm very positive i'm gonna be kickin A** and not care about the names. LET'S GET IT ON!!!!!!!!!!!!!!!!!
swheels is offline
Old 08-12-2009   #15
Re: The Dirty Girl
I thought x18s all had a single headlight, at least all the ones I've seen do. Did you swap the fairing on from something else?
afpreppie04 is offline
Old 08-12-2009   #16
Re: The Dirty Girl
Swheels has the x7 bodywork on his x18
Old 08-12-2009   #17
Re: The Dirty Girl
wow I totally missed mod #17. Thanks.
Old 08-12-2009   #18
Re: The Dirty Girl
np, S could not possibly list all the things hes done to that bike
Old 08-12-2009   #19
Hooligan
SpyGuy's Avatar
Re: The Dirty Girl
Well, he COULD, actually , but by the time he's finished, he would've missed the dealine for the calendar contest.
SpyGuy is offline
Old 08-13-2009   #20
Re: The Dirty Girl
no its cuz he prolly forgot half of it lol
Closed Thread
Page generated in 0.37076 seconds with 75 queries
