My $100 X15 Thread
Oldskoolturbo's x15 build
Custom 140cc x19
My custom built 110cc midbike
my x15 rebuild
Old 06-14-2008   #21
90GTVert's Avatar
Re: 4T Oil Change
Non-Synthetic motorcycle oil for wet clutches for break-in, your choice beyond that. I used Honda's non-syn then switched to Mobil 1 MX4T/Racing 4T.
I've never used a tq. wrench on the drain plug, just "snugged" it.
For the shavings in the oil... I would say you have 2 options.
1) Refill, start, listen for any odd noises, let it warm up, shut-off, drain, check for metal this time.
2) Pull the whole engine apart and see if anything is wrong.
I'd choose 1. It may be something left over from manufacturing. In that case, it's good that you got it out before starting the engine and you will prob never see it again.
90GTVert is offline   Reply With Quote
Old 06-14-2008   #22
125ccCRazy's Avatar
Re: 4T Oil Change
Originally Posted by meandino View Post
I'm just wondering. I just droped the oil and was looking closely at its condition. I noticed that there were metal shavings in the oil. Now in cars thats bad. I don't know bikes, but I'm thinking its on the same lines. This bike is brand new. I haven't even started it yet.
What should I do?
do as 90Gt said, change out the oil with good motorcycle oil, I'd suggest to go along with that is to get a magnetic drain plug or if you have a drill press and can find a small round magnet, drill your drain plug (not through) and silicone the magnet in the plug....between the silicone and the magnet itself it wont come out..This will attract any shavings and keep them from circulating through the engine..
Some metallic in the first oil change is pretty normal from break in, excessice metal to the point the oil looks grey, thats bad...
125ccCRazy is online now   Reply With Quote
Old 06-14-2008   #23
Re: 4T Oil Change
Should I call up the place I bought it from? Or just flush it out a couple times like you say to do?
meandino is offline   Reply With Quote
Old 06-14-2008   #24
Re: 4T Oil Change
I was thinking of going magnetic as well. So I'll go this route and just keep a close eye on it. If it gets worst I'll be giving them a call up. Thanks for your help guys.
Old 06-14-2008   #25
90GTVert's Avatar
Re: 4T Oil Change
I have a feeling if you call them they'll tell you it's from manufacturing.
Old 06-14-2008   #26
Re: 4T Oil Change
I was thinking the same thing. It wasn't much but but had one big piece. Maybe its even from the drain plug. Good thing I'm changing out the oil.
Also is it good to change out the transmission fluid while I'm in there?
Old 09-10-2008   #27
D.J.'s Avatar
Re: 4T Oil Change
there is no tranny fluid, when u add engine oil it lubes the tranny for u, its all built as one unit....
D.J. is offline   Reply With Quote
Old 05-25-2009   #28
demo401's Avatar
Re: 4T Oil Change
What should I do?
did you ever figure out about the metal shavings? i know this thread is old
demo401 is offline   Reply With Quote
what 100cc 4stroke oil do you use? pokebike 4Stroke Midbikes 17 12-28-2007 02:12 AM
4T questions Midbike 4Stroke Midbikes 4 06-13-2006 03:38 PM
i hope this will help junny007 Air Cooled Pocketbikes 4 07-16-2005 01:35 AM
how to change oil (newbie) john420 4Stroke Midbikes 1 06-25-2005 11:04 PM
Oil change gone wrong? cabridge 4Stroke Midbikes 10 04-01-2005 10:52 AM
Page generated in 0.25468 seconds with 40 queries
