Advance porting basics
4T Oil Change
Old 10-15-2008
API GL-4 or GL-5 gear oil
API GL-4 or GL-5 gear oil are these what the x 18 pocket bike uses? Because the aimsoil isn't recommended to use if ur bike uses these gear oils. Or do the x 18s use other gear oil if so what kind do they use? If the oil isn't it i so can't find the right synthetic oil that's JASA approved and wet-clutch compatable. I don't know they say it's not recommended but would it still work?
Old 10-16-2008
Re: API GL-4 or GL-5 gear oil
4 stroke engines dont use gear oil;-they use 4 stroke motorcycle engine oil..........the crank/piston and cylinder makes contact with the same oil as the trans gearing and the clutch.................
Some 2 stroke dirtbikes use gear oil in the crankcase...........the crank doesnt make contact with the gear oil...........the 2 stroke crank makes contact with the gas and oil mix so thicker oil can be used for the gears and the wetclutch..............
You dont use gear oil in a 4 stroke superbike............................Peace
Old 10-16-2008
I'm only asking if that amsoil I could use because it's not recommended if I used those gear oils so I can use it right?
Old 10-16-2008
Absolutely.....you can use the Amsoil 10/40 synthetic in your bike without any problems............horizontal aircooled engines use only motorcycle engine oil.....not gear oil.............Peace
Old 10-16-2008
Thank you.
Page generated in 0.54889 seconds with 28 queries
