Originally Posted by Mini "Ducati" ok everything is good. i was suprised to find a voltmeter. i dont have a multi meter but id like to try this the hard way. the kill/start switch button has a green wire and a black with white stripe. not what you sad. Where do i plug it? does anyone have a step by step for hooking up the estart? all i want is the e start and kill switch. What do i do? from those pics i posted do i have all the parts i need for e start? |
yes I did I said there should be 4 wires ;-two wires are the power and the green and black with white stripe is the killswitch wires...........scroll down...
Its harder to check the leftbrake handle and starter switch seeings these switches activate from a ground as a ground trigger...........
do you have one of these pictured below?
