My $100 X15 Thread
Oldskoolturbo's x15 build
Custom 140cc x19
My custom built 110cc midbike
my x15 rebuild
Old 11-06-2009   #221
monsta1780's Avatar
Re: Custom 140cc x19
yea true, but u can get bangin deals like me and be gettin an x15 125, well really 100 cuz i didnt get the headlight
monsta1780 is offline   Reply With Quote
Old 11-10-2009   #222
Just out of curiosity...
Does the 140cc krp/yx engine just bolt onto a x18 frame??
Does the stock exhaust able to use with this engine?
Supposibly im getting my engine in 2-5 days because i paid extra for shipping..
I was thinking about going with a red/ black theme and got that black krp engine with red air filter... i'll be waiting longer for this exhaust, that im thinking about getting.. .should i?
or can you prefer me to a good exhaust
i thought this exhaust would go along with the style im going with
http://www.pocketbikesunlimited.com/...EDMAN_SIDE.jpg
iSnapped is offline   Reply With Quote
Old 11-11-2009   #223
briansX19haulsass's Avatar
Yes your engine will bolt into the crate just fine.....
You can bolt the stock pipe on if you have to but a perfromance exhaust system is the way to go. And it really does let these engines achieve to their fullest...
briansX19haulsass is offline   Reply With Quote
Old 11-11-2009   #224
Mornin brian..
So your saying there is plenty room for the engine?
I really just ordered it two days ago, but payed like 80$ extra to get here in 3 days.
It cost me 770$
But yeah... i can take the 110cc off and just put the 140cc in the place of it? i thought you had to do some work to yours? whats that about... and what kind of exhaust do you have?
i think the redman exhaust looks kick aszz
Old 11-11-2009   #225
Smile Re: Custom 140cc x19
I know I had to do some cutting of the front frame supports to fit it in because my is a X19 your X18 doesnt come with any front frame supports.
And i run the exchaust from PBU for 189.99 in the GS59 section of exhasut pipes.
Old 11-11-2009   #226
So yes thats all you have to do is take the 110cc mtor off and put the 140cc motor and carb in place of it.
BTW what carb are you going to be running? Mikuni VM? OKO? Keihen?
Old 11-11-2009   #227
Ima be runnin a mikuni carb.. stock until i get that
Old 11-11-2009   #228
monsta1780's Avatar
ohh god stock
Old 11-11-2009   #229
NO! Not the stock 19mm carb on a 140cc!!!! Its stupid enough to runa stock excaust but a stock carb to thats just a waste of time and money if you ask me.
Old 11-12-2009   #230
what you mean a waste of time and money?
Old 11-12-2009   #231
monsta1780's Avatar
becuz if ur puttin a stock 19mm carb on a 140cc you will be lucky enough if the engine runs, lucky enough that it will even go anywhere. When you run such a small carb on a big motor, your very much restricting the motor from what it can do
Old 11-12-2009   #232
Arrow Re: Custom 140cc x19
It will run just a waste because your engine wants more air and fuel then that carb can get to it and the excaust will give the engine alot of back pressure and will bot add up to make a lot less HP then what the motor was meant to be at....
Old 11-12-2009   #233
what kind of carb do you guys recommend... ?
Can you link me to a decent priced and pretty good carb..?
And it doesn't damage the engine.. right?
Old 11-12-2009   #234
Kevin
K-Pac's Avatar
Engines usually come w/ MOLKT 26mm's. That might work but hasn't proven successful for me...
I would get a 26mm mikuni. I think there like $100.
K-Pac is offline   Reply With Quote
Old 11-12-2009   #235
SPB Mod Master
XR 100's come with 26mm Mikuni carbs.....I have 4 of them somewhere in a crate...I got them all on ebay for a killer deal from a dirtbike salvager.....A couple carbs are like new and dont look like they were used very long and 1 looks like it hasnt been used at all.Good luck
Old 11-12-2009   #236
No not even stuff like that I am talking about OKO's or Mikuni VM's the real stuff not thed chinese nock offs...........
TBolt USA, LLC » Pit Bike Engine Parts » CARB KITS » MIKUNI 26MM CARB KIT
TBolt USA, LLC » Pit Bike Engine Parts » Big Bore and Stroker Kits » Trail Bikes OKO 26MM Carb Kit
Old 11-13-2009   #237
Sounds good... i guess ill buy the 26mm oko carb kit..
Thanks for the ideas... and for exhaust-- suggestions?
Old 11-13-2009   #238
PBU big bore pipes are alwas good!
Old 11-13-2009   #239
monsta1780's Avatar
or you can make a frankenstein pipe
Old 11-13-2009   #240
Kevin
K-Pac's Avatar
I have a Yoshimura but I would go with the PBU since its easy installation...
Page generated in 0.33718 seconds with 76 queries
