| Re: electric system if youre telling me you think your batterys good and theres a different problem;-there shouldnt be any type of charging voltage or be any voltage over the same voltage as battery w/o it running when the bike is running,,,If youre getting current to the battery thats higher than initial voltage when its running;-the batterys crapped out/gone/caput.Any of those rechargeable ride on toys have batteries that are the bare base acceptable unit that will allow it to work for a while but not forever........The hotwheels battery may have the ability to be charged ;-but is good enough to withstand a load test??Was it charged with the right recommended charger for recommended time?????
I told you a few posts back to have the batteries totally eliminated on the suspect list by having them tested at Advance Auto Parts or Walmart auto center....They do load tests on batteries for free............
You never stated if you did or didnt and so now im guessing you never did and dont want to spend the $40.00 for the wetcell replacement battery or order another cheapo from the internet until youre convinced of the problem and if you go and get a troubleshooting manual ;-the first thing they suggest is to fully charge battery and have it load tested...........
If you read the top of the battery it says that max charge method is a 7amp quick charger x 30mins and a standard charge of less than 1 amp[0.7a].....The batterys output is designed for 6.5 amps an hour of continuous power...These superbikes run off of the a/c powered stator and the rectifier converts the a/c power to d/c just to charge the battery;-it does not run off of the battery.........
