My $100 X15 Thread
Oldskoolturbo's x15 build
Custom 140cc x19
My custom built 110cc midbike
my x15 rebuild
Old 05-27-2009   #1
Cool Gear shifter bolt always loose
Is there a way to make it so that bolt don't come loose after riding the bike a couple times? When that bolt come loose its really hard to shift gear, one time it actually came off while riding and I had to drive home on first/second gear.
When I make this bolt too tight, I can't shift, so I have to loosen it a little, but then it keep getting looser and looser each time you ride it.
Anybody else getting this problem?
Thanks.
spidy08 is offline   Reply With Quote
Old 05-27-2009   #2
Re: Gear shifter bolt always loose
Locktite dude I used red and made a little sleeve that I put in it at the hardware store. Good luck but make it snug and let it sit for a few hours for the locktite to set
remzhaffeyle is offline   Reply With Quote
Old 05-27-2009   #3
SPB Mod Master
Loctite sets up almost right away.........Friction from torquing is what sets it off............
The best way to keep your shifter bholt tight with the addition to loctite is getting a grade 8 bolt screw set and putting in a screw thats 1/4" longer and adding a jamb nut also..................Peace
Old 05-28-2009   #4
some white x18
coletrain's Avatar
hey my perfect fix was not loctite take a small drill bit and drill thru the top of threaded part and put a small metal pin or nail and bend it around... also make sure there is room for the nut and use a soft nail/pin so u can just cut it off with wire cutters if u need it off
coletrain is offline   Reply With Quote
Page generated in 0.17179 seconds with 26 queries
