My $100 X15 Thread
Custom 140cc x19
Oldskoolturbo's x15 build
My custom built 110cc midbike
my x15 rebuild
Old 04-11-2005   #1
How To: Timing advance RX12 110CC or any other 4 stroke
This mod will allow you to relocate the pickup sensor on your flywheel so you can advance the timing. Perform this at your own risk, it works great and is reversible but dont blame me if you do it wrong.
Step 1: remove the flywheel cover using an 8mm socket.
Step 2: remove the pickup sensor by removing the 2 8mm bolts
Step 3: What you want to do is lengthen the mounting holes so you can slide the sensor downward. This will make it pickup the signal from the flywheel earlier causing the advance in timing. Before you start mask off the flywheel cover and tape off the sensor to protect everything from the metal shavings.
Step 4: It is VERY important to ONLY lengthen the holes upward, so that when you remount the sensor, it can be slid downward. The lower end of the holes are left untouched so that if ever you want to return the timing back to stock, you know exactly how far to slide it back up. When you are finished grinding be very sure to get all the shavings of the sensor and out of the cover, THIS IS VERY IMPORTANT!!!!
Step 5: Remount the sensor sliding it down in its new postion. Remember that 2-3mm advance is plenty, any more than that and you can cause serious damage.
Step 6: Install the side cover and start you motor, listen to what the engine sounds like. If done correctly the engine will run and sound alot better. If done wrong you will hear a pinging noise called detonation, meaning you moved the sensor to far. If this happens take the side cover off and move the sensor up just a tad and try again.
When done right You should feel a good power increase all the way through the power band.
This mod is reversible if done right, and only takes 10-20 minutes.
And as always.... if your motor blows up............dont blame me
al300ex is offline   Reply With Quote
Old 03-13-2008   #2
x15prosteveo's Avatar
Re: How To: Timing advance RX12 110CC or any other 4 stroke
will this work on a x15 and has any one done this yet and how did it work get back to me ?
x15prosteveo is offline   Reply With Quote
Old 03-22-2008   #3
125ccCRazy's Avatar
unless the newer engines have this type of ignition the answer is NO, this is a totally different ignition than most 4 strokes.....Your bike should have a flywheel with the pick-up and charging coil under it...........If you want to have adjustable timimg and want quicker RPM's go with an Inner Rotor Kit.......
This is a great idea on this style ignition, unfortunately all the 4 strokes dont have this set up...
RX12 110cc 4 stroke 4 speed jayz 4Stroke Midbikes 47 06-02-2008 11:27 AM
4 stroke Engine Talk.. 110cc, 49cc, 70cc? what do I have? Michael_K 4Stroke Midbikes 28 09-13-2005 11:26 PM
How To Timing advance RX12 110CC or any other 4 stroke al300ex 4Stroke Midbikes 8 08-15-2005 12:53 AM
any size difference in 70cc X6 and 110cc RX12? boost'n 4Stroke Midbikes 12 04-02-2005 12:12 AM
Page generated in 0.16521 seconds with 25 queries
