Originally Posted by gera229 which engine would be better and more reliable lifan or loncin (110cc used in the x 15s x18s and x 19s) or are they similar? Would they both last the same or if not which one would last longer and by how much? Please answer all questions. Thank You. |
I've had both and both are very simular in reliability and performance until you get to the Lifan with the clutch on a secondaty shaft and not mounted to the crank, then those are better engines...
Are you looking into a new engine?? if so what size?
