I might order the R32 interceptor from mini pocket rockets. But i have a couple questions i would like to ask. 1.whats better auto or manual and please explane how to shift. 2. how often do you change the oil and what type. AND any more info will help. Im new to this. thank you and im sorry if this has already been asked.
i have the same bike form same place. dont even think about it, just get it, lol. i would get the manual cause you can get it running faster with a clutch then auto. i will explain how to shift later, its very easy, learn it in 5 minuts on these bikes.
You should change the oil after every couple rides or just check yourself by pulling out the dip stick and seeing if it has enough oil... Everyone changes their oil at different times, so the most accurate way would just to be to read the dip stick. As for what type of oil you would use, for your break-in process I would use Motul non synthetic motorcycle oil, and afterwards just use the same brand but in synthetic oil. I have an automatic X19 and it's not that bad... I have driven my friend's manual and I do have to say that they have much more problems with the clutch, gears, foot shifter, kick starter, etc. but that's just my opinion, many may disagree... I haven't had a problem with my automatic X19 once? Maybe a couple minor things but that would only require tightening a screw. So yeah, good luck! I would also go with the X18, it is more of a track bike out of the box and the X15/X19 model's do have some problems with the swingarm cracking, and the frame wraps around the bike leaving no clearance for if you ever want to modify the bike with an aftermarket exhaust.
Is it true the r32 auto has no kick start? And how does it charge? And im ordering it tommorow if i get this info quick enuff. And any outher tips you think i should know will be great help. THANK YOU ALL
go manual for sure. you hold the cluch"thats the left hand brake" then you push down with your left foot on the shifter. all the way down is 1st, up one is neutral, up again is 2nd, up again is 3rd and up again is 4th. thats it. now your ready to ride.
He's ready???? You just left him sitting in his driveway in first gear with the clutch in.
i dont know where you et your info from but i had a guy make a exhaust pretty easy for my 15. maybe your skills aint worth a **** for making exhaust.
Go **** yourself ya idiot and stop attacking every post I make like you know somerhing, you just joined these boards and try to act like a professional calling everyone a cat and on top of it all you abuse your wife and say about how she is a moron for not getting the door for your X18 Delivery. Just sit the **** down you idiot. The X18 has MUCH MORE Clearance because the frame doesn't wrap around it and that's a fact. Now go ride your bike comparing it to a 600cc and claiming your swingarm will never break.
R32 Auto = No kick start because no neutral gear
How does it charge? Plug the charger that comes with it into an outlet in the wall and then their is a place you can plug the other part of the charger near the fuse on the bike
for one i am not attacking your posts, just saying your skills arent up to par if you cant get a exhasut towork on the 15. second, i dont have a 18, hince my screen name you dumb ****, third, how the **** did i just join when i have been more active on this site and others as well with more posts then you. and how the **** you came up with me having a 18, guess you are too stupid to read too. so go ahead and act tough on here like you always do when feeling threatened cause you dont know **** about these bikes. and no i dont think i am a professional cause believe me i am not, but obviously i know more then your cum guzzling azz. now go back to your little scooter site since thats where everyone hates you the most anyways. ****ing dipshits, i swear, get your knowledge up before you **** with me. and i can promise you i have helped alot more people on this site then you have or ever will. you are the only one that has a negative opinion of me and everyone else.
If you guys wouldn't mind, be done with the bashing or pm it. I've got three kids that also happen to like pockets, and like to get on here with me. So, I would appreciate if both of you would just agree to disagree. You've both seen this bashing doesn't fix anything. If you're mad, be mad; but please think of the rest of us with kids, and all the other kids on here. k?
im ordering the auto R32 tommorow from mini pocket rokcets. One last thing my little cousine wants one can a 13 year old ride one, and can i please have some info on breaking in the motor like the half throttle thing and any outher stuff. every one so far has been such a big help so thank you. o ya and how fast does the R32 realy go
lol, yeah man i hear ya he is just the only member on here that gets my blood boiling. it has been so peaceful around here for a while cause he hasnt been on here. sorry bout that and i will keep it to a minimum.
yeah if your coussin has any motorcycle experience he would be fine, just take it easy for a while to get used to. and as far as break in, just dont give more then half throttle for 4 tanks. and make sure you chnage that crappy oil before you even start it. just use a good 4 stroke motor oil, non synthetic till broke in. thats about it for breakin, just make sure all motor mounts are tight and the other bolts too. and i am 5'6" and 135lbs and mine went 50 out the box. with just a carb upgrade i am going 59 now. so they are easy to get speed out of, just have to get the crappy parts off first, lol. good luck man, holler if you need some help .
I don't think it would go 50 with an auto because after i broke mine in my r32 went 46.3 max speed b4 it was slower out of box and i checked on a gps their pretty accurate im pretty sure. So refer to a manual. They go much faster. So i sold my x 15 and wanted to buy a manual so i bought the x 18. [= And I believe manauls last longer.
Reason: add
Thanks, I do appreciate it. Just keep an open mind when it comes to people on here; ya never know who is on the other side of the keyboard. Heck, I've learned stuff from 14 yr olds on here...
i completely understand, i have a kid too, i wouldnt want him to read this stuff either. and to gera i didnt know he was talking abot a auto. so yeah the auto are a bit slower. i would get a manual, the auto's are boring.
