| Re: what does it mean to port and polish and the engine? in a quick rough overview, you grind down and sand down/polish the inside of the head and intake, especially around the valves and it will cut down the air resistance for the air/fuel in, and then the exhaust gases out. faster flow means less sluggish motor, meaning you go faster. how much this will help performance varies by the motor, the design, the quality of workmanship, and how good of a job you do. go too far and there could be gaps, meaning less compression, meaning losing power.
also keep in mind if you get 3% gain of a 7.5hp motor, chances are the only noticable change will be what you imagine in your head. |
