| Re: x19 auto elec start prob The safety switch is at the clutch handle in the perch...sometimes the little plastic pin on the microswitch in the perch gets stuck and cannot retract out to complete the solenoid power circuit to power up the starter solenoid so when the starter pushbutton is pressed it grounds the ground leg of the solenoid harness wire to the frame completing the starting circuit to activate the solenoid to crank the starter..........
If your clutch perch microswitch wires have been cut off and swapped over to the front brake switch then you must squeeze the front brake to get the neutral safety lock to unlock.....
You can unplug the harness plug going into the clutch handle and twist the two wires from the plug at the harness together then go to the rear taillight connector and 4-6" before the plug cut the green wire with yellow stripe..After that you only have to turn on the key and push the button without squeezing anything. To rehook up the brakelight you will need to make a small harness to hook the rear brakelight up the right way to the front brake switch and have the rear brakelight activate like a real 1:1 bike...The best way would to use a 15 amp relay kit for hooking-up aux.fog lights to make a real brakelight circuit and add a real running light too with an 1157 bulb socket for more authenticity.........Peace
