Advance porting basics
4T Oil Change
Old 08-07-2008
racer#7's Avatar
Re: X7 Hit 93 Mph!!!!
i dont think your doing 93 mph....specialy with the stock head and haveing only around 11 to 12 k to play with rpms
  #22
Old 08-17-2008
$400.00 bucks!!! Shipped with carb, intake, inter rotor kit, oil cooler and oil lines, kick starter and shifter!!!! If your interested send me an email qwerty2145@netzero.com and I,ll put you in contact with the guy. Also they make a 170cc bore kit and race head that will make this little motor put out over 18 HP!!! But you would have to beef up the frame. With just the stock motor I have its starting to bend the rear axle and axle stops and its starting to twist the sprocket of the rear wheel!! They have a 60mm bore and only a 53mm stroke so they rev like hell!! I,m turbocharging mine now! still in progress and my inverted forks!!!!! here are some pictures
  #23
Old 08-17-2008
I'm going to try to run the carb u turned around beside the turbo and the exhaust will be something like shown in the picture. I'll wrap the pipe with some header heat wrap so I don't loose thermal energy and heat shield the turbo from the carb and fuel tank so I don't catch fire!! I was thinking of running two oil coolers one down each side for all the heat I'll be reintroducing back in the engine. I would like to run some kind of CAC but there is no room and it just fits so well on top of the engine. I'm hoping for 6 psi boost, I'm modifying the turbine and housing to get as much as I can from the small displacement and I found Someone who will grind a cam to my spec so I can eliminate the valve over lap and move the valve timing. I bent the turbine shaft already trying to reduce the induction diameter on the turbine. So I'm kind of on hold Intel I get a new one. And I need to find out more on running a throttle valve before the turbo. I'm not sure what effect it will have on the seals when the throttle snaps shut. If anyone has any advice I would be great full to hear it.
  #24
Old 08-17-2008
u should've put 18t front sprocket which is max it wouldve done faster maybe 95-99 mph 1st to hit 100mph maybe..
  #25
Old 08-18-2008
they are 399.00 not sure what he paid but look at this site http://www.holeshotzperformance.com/
  #26
Old 08-19-2008
coletrain's Avatar
can some one some one tell me all the differences between an x6 and a x15 im getting slightly modded x6 and want to know why and how much better the x15 is
  #27
Old 08-20-2008
Hey Ganthos, Ya thats the motor. its says 399. but when you click on it the price jumps to $495.00 Thats the same thing I have but I didn't get it from them.
  #28
Old 08-20-2008
Gera229, With the 18t I don't think there would of been enough HP and It would of mostlikely lost speed. I think, If I had one I would try it.
  #29
Old 08-21-2008
racer#7's Avatar
the YX motor wont put out 18 hp with the stock valve head end of story
and have fun haveing the power your motor wont last only a few rides near 16 hp at that time 15.5 hp your clutch starts slipping
  #30
Old 08-21-2008
swheels's Avatar
Think he was talking about a 18tooth front sprocket.Not 18hp the yx motor's come with 11.5hp to and that's at the rear wheel and i believe 16hp the crank.11hp to start with is not bad at all conisidering the price.Plus i heard from a little birdy that there is suppose to be some new hot cams coming out.And all the takegawa S series roller cams will work with the roller heads.
  #31
Old 08-21-2008
racer#7's Avatar
with those types of cams alote of stuff is ognna be needed to keep the motor just a tad reliable
the most i would do to keep a yx motor reliable is v2 head with a nice cam 28mm carb and high comp piston it comes with other goodies as it does already
but other then that the v2 head alone makes the clutch want to give up
  #32
Old 08-21-2008
SpyGuy's Avatar
Old cowboy saying:
"The best way to set a record is to be a good ways off from any tape measures, scales, or witnesses."
As was found on another website:
"Post pictures/video or it didn't happen."
I don't care if you only got it up to 80 - show a video anyway! I like watching someone doing some insane mods on a bike or car, and then showing it off. Somewhere, I have a video of a guy blowing the doors off a newer Trans Am on the quarter-mile ... riding a snowmobile!!) And if you really did legitimately hit that top speed, congratulations - can't wait for the 100mph mark video!
  #33
Old 08-27-2008
rkfinch23's Avatar
all ********............... 18hp won't do it, my motors made 18+ before the nitrous. keep trying
  #34
Old 09-08-2008
These are some stats i found on a ogm yx150 motor . With 11hp i don't think you can do 93mph . Maybe 93kpm though .
OGM 150CC YX ENGINE
[ogm-150]$499.00
OGM 150x Complete 150cc Horizontal Race Engine
Engine Specs:
150cc Air Cooled Four Stroke
53mm stroke
60mm bore
Compression Ratio: 9.2:1
Power and Torque: 11HP/9500°500R/min
Max. Torque: 11N.m/5500°500R/min
KLX110 Style Head
Transmission Specs:
4-Speed All Up Transmission (N-1-2-3-4)
Manual Clutch (start in any gear)
Transmission Ratio:
First Gear: 3.272 (11/36)
Second Gear: 1.937(16/31)
Third Gear: 1.35(20/27)
Fourth Gear: 1.043(23/24)
Included:
OGM 150x Engine
Lightened Oil Slinger
Inner Rotor Kit
Wire Harness
High Rev CDI Box
26mm Carb
Intake Manifold & Gasket
Air Filter
Oil Cooler
Kick Start Lever
Shift Lever
Dress Up Kit 30 day warranty
  #35
Old 09-09-2008
racer#7's Avatar
i think we all know what the 150 brings.... and that 26mm carb is crap on the bike
  #36
Old 10-18-2008
I have done some major modifications to the stock YX 150cc engine!!
V2 roller race head, Modified the intake port and ported and flow benched the head! Drilled oil passages so now the rockers are pressure lubricated!
165cc Bore kit!
Custom hand ground Camshaft!
custom built high flow oil pump!
Installed piston cooling nozzle to cool piston from returned heat from turbo!
Re enforced right side crank case between crank and clutch shaft to prevent case cracking!
Install custom IHI RHB3 turbo, Turbo is now VGT Ball bearing Turbo!!
Replaced all engine bearings with stronger High temp multi ball, ball bearings!
Race balanced crankshaft!
Re wrapped outer mag stater to have performance of smaller and lighter flywheel and still run lights!
1.5" YZR race muffler on custom 1.5" exhaust!
Check out the pictures! I will provide video of the 100mph+ run soon as my project is complete! Watch and learn how speed and HP is made!
This will be the fastest pocket bike ever built! Or fastest anyone will dare to ride!
  #37
Old 10-18-2008
165cc Bore kit!
They have guys running super pocketbikes 110-120 mph on the Bonneville Salt flats and the record is 140mph..................Im pulling 88 mph without any thing but race fuel and propylene oxide with a 146cc engine and some engine rework.....Peace
  #38
Old 10-18-2008
165cc Bore kit!
  #39
Old 10-18-2008
I don't think I will even come close to 140!! Thats just crazy! Are they china made pocket bikes going 140? You would have to have balls the size of basket balls to even be on a pocket bike going 140!!!! I will be happy if I cross the 100MPH mark.
  #40
Old 10-18-2008
Do you have any more info on the bikes doing 140? Motor? Bike?What kind of drugs the riders are on?
Page generated in 0.41954 seconds with 74 queries
