Go Back   Pocket Bike Forum - Mini Bikes > Off Topic > Chat
Phoenix 125cc Streetbike review *ready to ship*
Are the little 50cc dirt bike pocket bikes any good? Pics inside
What Is The Best And Fastest Pocket Bike??
Fastest Bike!
what kinda cars/bikes you guys drive??
Nitrous
Age Poll
B1 Replica Vs Polini 6.2 Hp
2005 PocketBike Calendar
pocket bike videos
Old 10-08-2004   #1
asnboi512's Avatar
pocket bike question please help
i don't know if this is in the right section of the forums ( im new to this stuff) but if its not here's my question, i just bought a pocket bike a week ago and i've been riding it ever since, but today it broke down.. i started it up this afternoon with choke closed waited for it to warm up then opened the choke then gave it a few revs to make sure it wouldnt bog out when i took off but as i did it just stalled, when i tried starting it again it reved up really high with the choke closed again and wanted to move on its own, it won't stay running unless i keep the throttle held down with the choke open.. i thought it was the bad gas mix so i drained the carb/tank and made a fresh mix and still didnt fix my problem so i thought the carb was clogged, i took it apart cleaned it with carb cleaner put it all back together and it still does the same thing, i also changed the fuse just to make sure it wasnt that.. sorry for such a long entry
CLIFF NOTES: Bike will start but rev's high on its own, won't run with out me holding throttle when choke is open, drained gas completely from carb/tank put in fresh new mix, problem still existes.. bike is only 6 days still on 2nd tank of gas put in new fuse, its a super pocket 49cc
Thanks for your help if u can provide any
asnboi512 is offline   Reply With Quote
Old 10-08-2004   #2
hmmm
this is an interesting case,,,do you know what ian idle screw is? maybe that needs adjustment thats reallly weird hmm
Old 10-08-2004   #3
asnboi512's Avatar
yeah, i work with cars all day but this little thing is really bugging me i have been playin with the idle screw and fuel screw all night i got to to run at low rpm at idle.. but it just shuts off after i give it some gas, and when i do get it to take off i give it full throttle but when i let off it shuts down on its own
Old 10-08-2004   #4
maybe
maybe the throttle linkage is weird and maybe its pulling on it? umm check that the throttle cable is not pullin the carb open
Old 10-09-2004   #5
asnboi512's Avatar
its not i checked everything i think its the carb not getting fuel or somthing i noticed the air filter and intake box had gas in it from it shooting back out when i was trying to rev it
Old 11-03-2004   #6
Originally Posted by asnboi512
its not i checked everything i think its the carb not getting fuel or somthing i noticed the air filter and intake box had gas in it from it sooting back out when i was trying to rev it
what is the expantion chamber thing between the carb and theblock ? [ velocity, volume, what?]rrocketman 417 353 1522
rrocketman is offline   Reply With Quote
Old 11-03-2004   #7
check the carburator there could be a leak somewhere
David 15yrs is offline   Reply With Quote
Old 11-03-2004   #8
im new here and i have the same problem i never can get it to stay running without reving it it will stay on for a lil bit ith out reving but it still shuts off like in 5 seconds
orangeSuzuki is offline   Reply With Quote
Old 11-04-2004   #9
asnboi512's Avatar
if it won't stay running then you have an air leak, or bad carb, im not as much of a noob anymore, but i havnt had any problems in awhile, if there is the slightest air gap or bad gasket between vstack-carb-manifold-head it will not idle and u will have to hold the throttle to keep it running, replace all your gaskets and see if it works. then look at the manifolds inserts see if you over tightend them so that the inserts pull themselfs out, that will cause you to have a bad idle or not run at all.. look for fuel leaks too between carb and manifold
Old 02-13-2005   #10
check the fuel line the air intake the carburator probly has a leak if all else fails by a new carb ive had this problem before what model is the bike?
gtman is offline   Reply With Quote
Old 02-13-2005   #11
i had a super pocket that did that once
Old 03-27-2006   #12
Re: pocket bike question please help
I would just take the whole carb assembly apart, check that all gaskets are doing there job, and that they are alligned right. It sounds like your carb needs some serious tuning too. but yeah, If its spiting out gas it is most likely a gasket problem.
Gota_40oz_RootBeer is offline   Reply With Quote
Old 03-30-2006   #13
JD-7's Avatar
check for a leak at the exhaust port.
JD-7 is offline   Reply With Quote
Old 03-31-2006   #14
m_helstad's Avatar
Try adjusting your carb.
m_helstad is offline   Reply With Quote
Old 03-31-2006   #15
m_helstad's Avatar
WOW, I did not realize this was over a year old.
Honolulu Meet? rossi808 Southwest 33 05-20-2009 07:25 AM
When you first get your Cag Pocket bike! insyder Air Cooled Pocketbikes 19 06-27-2007 09:18 PM
My New and Improved Pocket Bike (56k warning!) GfµnK Air Cooled Pocketbikes 9 09-11-2005 05:46 AM
Pocket bike noob....Help or tips please? amanthebest Air Cooled Pocketbikes 6 08-11-2005 04:11 AM
What is the 'super' in super pocket bike? nheaps Chat 12 06-05-2005 02:25 PM
Page generated in 0.34880 seconds with 61 queries
