How-To Carb Intake Porting
How To's: Port your Carb
How to jet your bike 101
Old 04-29-2007   #1
wambamthankyoumam's Avatar
How to: Adjust needle clip *pics*
This should be helpful to a lot of people!
Also why you are in there might as well taper your needle too! Just chuck it in a drill and carefully run it on sandpaper, I used 220 grit and smooth out that sharp edge it has.
Dustin
Search keywords: adjust needle clip how do I what is bogging boging bog 1/4 3/4 throttle throtle taper
wambamthankyoumam is offline   Reply With Quote
Old 11-18-2007   #2
spd_demon89's Avatar
Exclamation Re: How to: Adjust needle clip *pics*
how do you put it back together, everything is adjusted (by the way thanx ) when i screwed it back on the throttle handle was pulled back full throttle. please help!!!!!!!! (and send pics too!!!!)
spd_demon89 is offline   Reply With Quote
Old 02-26-2008   #3
so what if this is done? im newbie sorry=)
heaven295 is offline   Reply With Quote
Old 02-27-2008   #4
what will this do when i do the adjusment of needle. rookie here
Old 04-01-2008   #5
hydroponikronik's Avatar
i tapered my needle using 220 the took 2000 grit and polished it!!
hydroponikronik is offline   Reply With Quote
Old 04-14-2008   #6
davation's Avatar
i have a question on this procedure, if i put a bigger jet in the carb, and moved the c-clip to the 1st position (less gas), does that not defeat the purpose of the larger jet?
davation is offline   Reply With Quote
Old 05-25-2008   #7
Thanks for this nice "how-to" article.
Could someone explain the merits of this needle modification?
My new CAG seems to be bogging at higher RPMs when the fuel tank is down to about 3/4 full. I am guessing that this bogging is due to the engine running rich. I thought I would try to move the needle down a notch (clip up a notch) to lean it out.
Thank you in advance for any help.
frog is offline   Reply With Quote
Old 08-19-2008   #8
THOMCOR RACING's Avatar
Thumbs up Re: How to: Adjust needle clip *pics*
Thanks for the detailed "how to" been lookin for 1 of these with pics. peace.
THOMCOR RACING is offline   Reply With Quote
Old 10-04-2008   #9
when is it important to do this? when you get bogging do you make it leaner? what would be a good time to make it richer? would it be a good idea to make it richer after i put an aftermarket air filter on it?
801adrenalinejunky is offline   Reply With Quote
Old 10-03-2009   #10
Nice
but what exactly does this do? haha
GreenMTX is offline   Reply With Quote
Old 10-17-2009   #11
why do we need to sharpen the needle
shawn5101995 is online now   Reply With Quote
Old 11-09-2009   #12
idk why maybe to get it to slide in easier, or maybe just the feeling of a clean slide without fuel and oil all over it. Im getting good at this stuff now thanks to this website and the guys
2wheelxtreme is offline   Reply With Quote
Old 02-03-2010   #13
wwill93's Avatar
you probly put the barrel on backwards, try spining the black barrel 180 degrees and then putting it back in (or untill the cable end is opposite from the lttle screw sticking out
wwill93 is offline   Reply With Quote
Old 02-07-2010   #14
xhalemotorsports's Avatar
i'll help the thread out,
Sharpening the needle helps atomize the fuel=Good.
Moving the clip on the needle effects the amount of fuel from 1/4 to full throttle.the typical setting on cag carb needles is 1st or second notch from the bottom.thus letting the most flow through the jet.
if you get a bigger jet,you can put the clip higher on the needle.
xhalemotorsports is offline   Reply With Quote
Old 4 Weeks Ago   #15
Where is the best position for the clip? Or is it trial and error to match the bikes mods?
NozMonkeys is offline   Reply With Quote
Old 3 Weeks Ago   #16
typically the bottom notch or the one above that.
Old 3 Weeks Ago   #17
on newer bikes like 2008 and up have one position to put the c clip so what do i do for this situation
Old 4 Days Ago   #18
QFT I just pulled out my needle on my Cag 2010. A little off topic: It says manufactured in 4/09 on the label, does this mean it's supposed to be a 2009 model?
Here's a picture of my needle. Like shawn said, there is only one position for the c clip, and the larger, silver U washer just sits freely above the c clip, it doesn't actually securely latch onto the needle. I am having problems immediately starting my bike after riding it for a while. It usually takes me 20-30 min before the bike wants to start again after I kill it. Following the advice of fellow forum members, I pulled the needle to see where the c-clip is set and this is what I saw...
userix is offline   Reply With Quote
Old 1 Day Ago   #19
Bump. Is there anyway to adjust the lean/rich settings on this type of carb? Or would I have to buy a replacement carb? Thanks.
Page generated in 0.34155 seconds with 72 queries
