How-To Carb Intake Porting
How To's: Port your Carb
How to jet your bike 101
Old 12-03-2004
eaterofdog's Avatar
The first photo shows the stock intake. Pretty skanky.
The second photo shows the rough porting in progress. I used a grinding point on a drill press to evenly remove metal. I used lots of spray lube on the grinder and on the carb to keep the grinding smooth.
The third photo shows the finished rough grind. You can see how much metal was actually removed.
The fourth photo shows the finished carb. The rough grind was smoothed with 320 then 400 wet emory cloth to remove all scratches. Then it was given a quick polish with white compound.
The last photo shows close ups of before and after. The bore now merges smoothly with the lip.
Needle and jet adjustments are needed after this mod.
Make sure you keep the point and the carb oiled while you grind. The oil carries away the aluminum and keeps the grinder in good shape. Make sure you don't grind into the slide area or into the lip the choke sits on.
carb intake porting photos eaterofdog Air Cooled Pocketbikes 53 01-20-2007 10:17 PM
REVIEW: Billet 4 Petal Reed Setup and billet intake manifold from DDM... jman47cc Air Cooled Pocketbikes 9 08-31-2005 10:56 PM
How to: Hp Carb Tuning. Thanks to someone bmarley5780 2Stroke Midbikes 31 07-30-2005 11:49 PM
Badazztoys C1 17mm carb review BungeeGuy Water Cooled Pocketbikes 38 06-30-2005 12:09 AM
4spd Manual pipe, intake, porting...power wheelies and speeds over 60 mph genesisautoworks 4Stroke Midbikes 14 02-28-2005 11:08 PM
Page generated in 1.12584 seconds with 18 queries
