How-To Carb Intake Porting
How To's: Port your Carb
How to jet your bike 101
Old 12-03-2004   #1
eaterofdog's Avatar
The first photo shows the stock intake. Pretty skanky.
The second photo shows the rough porting in progress. I used a grinding point on a drill press to evenly remove metal. I used lots of spray lube on the grinder and on the carb to keep the grinding smooth.
The third photo shows the finished rough grind. You can see how much metal was actually removed.
The fourth photo shows the finished carb. The rough grind was smoothed with 320 then 400 wet emory cloth to remove all scratches. Then it was given a quick polish with white compound.
The last photo shows close ups of before and after. The bore now merges smoothly with the lip.
Needle and jet adjustments are needed after this mod.
Make sure you keep the point and the carb oiled while you grind. The oil carries away the aluminum and keeps the grinder in good shape. Make sure you don't grind into the slide area or into the lip the choke sits on.
Old 03-27-2008   #2
hydroponikronik's Avatar
Re: How-To Carb Intake Porting
well here is my first shot at it, i did it your way.
hydroponikronik is offline   Reply With Quote
Old 05-09-2008   #3
kgogarty's Avatar
great way to do it!
kgogarty is offline   Reply With Quote
Old 09-08-2008   #4
what is going on with the pictures, they dont work
jrosscp is offline   Reply With Quote
Old 08-09-2009   #5
what jet size should i use after this mod?
f2 matt is offline   Reply With Quote
Old 11-11-2009   #6
any luck on what jet size you used??? i dont know what i have for a stock one????
383stroker94 is offline   Reply With Quote
Old 12-22-2009   #7
supercharged1989's Avatar
awesome great pics what size bit did you use to drill with?
supercharged1989 is offline   Reply With Quote
carb intake porting photos eaterofdog Air Cooled Pocketbikes 53 01-20-2007 09:17 PM
REVIEW: Billet 4 Petal Reed Setup and billet intake manifold from DDM... jman47cc Air Cooled Pocketbikes 9 08-31-2005 09:56 PM
Badazztoys C1 17mm carb review BungeeGuy Water Cooled Pocketbikes 38 06-29-2005 11:09 PM
4spd Manual pipe, intake, porting...power wheelies and speeds over 60 mph genesisautoworks 4Stroke Midbikes 14 02-28-2005 10:08 PM
Page generated in 0.29999 seconds with 38 queries
