How-To Carb Intake Porting
How To's: Port your Carb
How to jet your bike 101
Old 09-13-2004   #1
Sydeshow MO's Avatar
Post How To: Install Meat Hook pegs on your Cag
You will need 2, 8X30mm hex head screws and a 5/16 drill bit, and oh... dont forget get your Meat Hooks.
1. Remove stock peg from mount. I used a corded power drill and attached the chuck directly to the peg while the mount was in a table vise. If you use this method you must use a drill that has a 1/2" chuck.
2. Use the 8X30mm nut and screw it into the meat hook like you are going to mount it to the peg bracket. This is where you want to setup how your meat hooks will mount. Higher will prevent LOWSYDING. Mark the bracket where the set pin on the meat hook will be going into the bracket. Drill a 5/16 hole where you just marked it.
3. Replace the stock allen head screws that tighten the peg mount to the frame. I dont know the size but you can find em at Home Depot.
4. Waaaa-Laoow... you now have the best racing pegs installed on a CAG.
If you notice in my pics, my meat hooks are mounted at about 10 o' clock. This is most comfortable for me and I never LOWSYDE on my pegs. I thought I was but it was actually my rear tire breaking traction from leaning to far over. You can set your to where you are most comfortable.
Old 08-17-2009   #2
gera_cag's Avatar
Re: How To: Install Meat Hook pegs on your Cag
where can i get that hooks?
gera_cag is offline   Reply With Quote
Old 08-18-2009   #3
Blind909's Avatar
scooterparts4less.com
Blind909 is offline   Reply With Quote
Meat Hook Pegs pilotdud Air Cooled Pocketbikes 49 04-13-2005 04:52 PM
PBU's Meat hook pegs b23ball23 Air Cooled Pocketbikes 9 02-27-2005 01:07 AM
D.S Meat Hook mounts now available!! DemonSpit Air Cooled Pocketbikes 17 11-27-2004 05:19 AM
Anyone mounted meathook pegs on Cag? Soulranger Air Cooled Pocketbikes 30 09-13-2004 09:00 AM
Page generated in 0.20549 seconds with 25 queries
