How-To Carb Intake Porting
How To's: Port your Carb
How to jet your bike 101
Old 06-10-2005   #1
Thumbs up How To: Make A Boost Bottle For You 2 Stroke Pocket Bike
WHY SHOULD YOU MAKE A BOOST BOTTLE? FOR ONLY ABOUT $10 YOU CAN IMPROVE YOUR THROTTLE RESPONE AND ACCELARATION.
HOW TO: MAKE A BOOST BOTTLE FOR YOU 2 STROKE POCKET BIKE
1:1ST YOU NEED TO GO TO YOUR LOCAL HARDWARE STORE AND GET MATERIALS.
MATERIALS
  • 2 FITTINGS SMALL ENOUNG TO FIT IN A CAN AND YOUR MANIFOLD WITH THREADS ON BOTH SIDES. I GOT MINE AT HOME DEPOT FOR $1 A PEICE.
  • LARGE TUBING LINE THAT WILL FIT ON YOUR FITTINGS. YOU WILL PROBABLY FIND IT IN THE SAME AREA AS THE FITTINGS. I GOT MINE AT HOME DEPOT FOR $3 FOR LIKE 6 FOOT OF LINE
  • YOU WILL ALSO NEED A BOTTLE SUCH AS A METAL ARESOL CAN. DO NOT USE PLASTIC.THE GAS AND THE FUMES WILL EAT RIGHT THROUGH IT. I USED A LYSOL CAN AND IT WORKED GREAT.
  • YOU ALSO NEED A DRILL BIT A LITTLE BIT SMALLER THAN THE FITTINGS.AND A TAP TO DRILL YOUR THREADS.
2: AFTER YOU GET YOU MATERIALS YOU CAN START BUILDING IT. FIRST YOU WANT TO TAKE THE TOP OFF OF YOUR CAN AND DRILL A HOLE WITH YOUR BIT. THEN TAP IT AND SCREW IN YOUR FIRST FITTING.
3: THEN YOUR REPEAT THE SAME STEP ON THE INTAKE MANIFOLD BUT ANGLE YOUR FITTING TO WICH EVER SIDE YOU ARE MOUNTING YOUR BOOST BOTTLE. THIS WILL HELP THE TUBING NOT TO PINCH AND LET NOTHING IN OR OUT.
4: NOW YOU CAN MOUNT YOU BOOST BOTTLE. WHEN DOING THIS MAKE SURE YOUR TUBING IS POINTED DOWN AND YOUR BOTTLE IS HIGHER THAN THE INTAKE MANIFOLD SO THAT THE AIR AND GAS MIXTURE THAT IS SUCKED IN CAN BE PUSHED OUT EASILY. I MOUNTED MINE MINE ON THE SIDE OF MY FRAME NEXT TO MY GAS TANK BEHIND MY BATTERY. MOUNT IT WITH 2 STRONG ZIP TIES.
5: NOW JUST CUT YOU TUBING TO THE RIGHT LENGTH AND SLIDE IT IN. THEN YOUR READY TO HIT THE STREETS AND SEE HOW MUCH MORE THROTTLE RESPONSE AND ACCELARATION YOU GET.
THIS PROJECT SHOULD ONLY COST YOU ABOUT 10$ AND ADD ALOT OF THROTTLE RESPONSE AND ACCELARATION.
I HOPE THIS WAS HELPFUL BUT IF YOU HAVE ANY QUESTIONS OR COMMENTS EMAIL ME AT KKUENZLER@TAMPABAY.RR.COM
THANKS
krisk is offline   Reply With Quote
Old 11-08-2007   #2
Re: How To: Make A Boost Bottle For You 2 Stroke Pocket Bike
could u post sum pics, it would help me alot.
J.glass is offline   Reply With Quote
Old 11-20-2007   #3
MATERIALS
THANKS
So... wat do u put inside the empty bottle once u drill it ?
blackhawk0785 is offline   Reply With Quote
Old 01-26-2008   #4
what kind of bike you do that on b/c im think about do that on my x1
aarons12 is offline   Reply With Quote
Old 01-26-2009   #5
i baught a boost kit for my mini moto for £16
TOM49cc is offline   Reply With Quote
Old 08-14-2009   #6
GhostPerformance's Avatar
Do ya really talk like that or is it a typo? Sorry but I like the concept but due to the grammar I got a headache tryin to correct the mistakes..jus wondering no offense if I offended
GhostPerformance is offline   Reply With Quote
ATTENTION all Cag owners...READ this Guide 12345 Air Cooled Pocketbikes 6 11-01-2008 08:06 PM
When you first get your Cag Pocket bike! insyder Air Cooled Pocketbikes 19 06-27-2007 09:18 PM
boost bottle & carb cleaning question FreeLoader101 Air Cooled Pocketbikes 7 06-17-2005 12:23 AM
Bike doesn't run right after boost bottle install prepsbl0w 2Stroke Midbikes 5 12-11-2004 03:39 AM
39 & 47cc CAG FAQ <-- READ TO AVOID PROBLEMS! Vbp6us Air Cooled Pocketbikes 2 08-25-2004 03:58 PM
Page generated in 0.19784 seconds with 33 queries
