| ok. with this mod you will experience better top end, better low and also better mid.
instructions:
1. take stock pipe off
2. make 3 cuts. one, the start of the expansion chamber(you will notice about 1.5 inches of pipe sticking in there*BAD*. the second cut is right where the expansion chamber goes from its largest part and going back small. the third and final cut is at the part where the first cut was, just back about 2 inches.
3. weld a "belly" in between the cones of the expansion chamber about 1.5 inches long.
4. weld the new expansion chamber to the cut you made in the headpipe.
5. reinstall!!
the pictures do a great job of explaining this. i have to admit, i DID NOT take these pictures, they are from the site and i found them while i was searching. the pics do a better job of explaining than i do.
this mod is great and better than a pipe i bought! it has pretty good power and great top end! |
