06-19-2006
| Senior Member | | Join Date: Dec 2005 Age: 30
| How to replace your nylon pullstart for a plastic coated cable Attached is a PDF file for installation of a plastic coated cable on a pullstart for either water cooled or air cooled minimoto engines.
With this mod you will NEVER have to replace your pullstart for as long as you have your minimoto. Time required:
30 mins Items required:
pliers
small vise grips
wire stripper/cutter
allen keys
ratchet set w/ screwdriver bits
napkins (to clean off the grease)
grease (to reapply onto the casing) Let me know how this install worked for you?
Schemo24 |
