| How-To's: Eliminate Engine Vibrations #1 - Reinforce the engine mount welds
#2 - Drill out hole in engine mount to mount for third engine mounting screw
#3 - Drill out and retap all engine mount holes to 8mm
#4 - Make and bend a mount to attach to middle engine mount using bottom three mounts
#5 - Rebuild upper engine mount and attach via frame, not upper mount holes
#6 - Add rubber washers and gromets to just about every nut and bolt
#7 - Drill out flywheel
#8 - Replace stock engine mount screws with aftermarket ones found at any lowes store
#9 - Ride and get to feel no vibrations! |
