| How-To's: JMD air filter mod Here's a tip that JMD submitted a while back. Its an airfilter mod that anyone can do on their own. Cost: $10.00.
---------------------- I play with my bike today. polished the intake and exhaust ports on the cylinder. Then I decided to make a K&N style air filter setup. Man this is a VERY EASY and inexpensive mod. I simply bought a $9 valve cover breather filter from Advance auto . Took off the original filter setup off, then the adapter plate and removed the baffle. I then placed the adapter and aligned it to the back side of the filter and drilled holes thru both sides matching the exact carb pattern. Then I bought some #4 metric screws to accomodate the longer filter, placed the adapter back on the carb and bolted the filter to the original holes. The adapter is plastic so it also doubles as a way to seal the filter to the carb. In all when I completed playing today , I was very impressed with the gains. A lot throater sound at idle and lots more mid when the power band comes in. First run I cruised it around almost mid throttle. Then let into it, the bike instantly pulled the front wheel for the first 6-8 feet and reached full throttle way faster. |
