Go Back   Pocket Bike Forum - Mini Bikes > Pocketbike Tech Talk > Mini Choppers
Pics of your choppers!
4 stroke chopper with 4 speed manual tranny
250cc V-Twin Scorpion Chopper
Gladiator 300XT DOT Certified Chopper
Check out these "mini choppers"
TrojAn's 110cc Chopper
sikk chopper review with video
lookin for sellers of 110cc choppers with 4 speed trans.
Video of Choppers
my chopper pic
Old 04-08-2005
tjferris's Avatar
4 stroke chopper carb tuning and spedo problem
Hi anybody have any tips on carb tuning? the larger jet with the spring on it is for adjusting at idle correct? is the smaller screw up and to the left of that jet the jet high flow jet or are these only one jet like the pb's? next question my spedo don't work?? i have the cable hooked up correctly behind the spedo and at the wheel it is a mechanical speedo any suggestions?
Thanks
Tim
Old 04-09-2005
tjferris's Avatar
Thanks
Tim
ok i think i figured out the carb the screw at an angle is the jet i need to be adjusting and the larger one below it is for the idle...let me know if i'm wrong
Thanks
Tim
Old 04-10-2005
tjferris's Avatar
ok i got the speedo figured out too, the instructions don't say which way to mount the forks, not that i read them in the first place so i used common sense and mounted the brake on the same side as the master cyl. well that was wrong took the forks off and turned them around now the speedo works just fine. I may in fact be mentally retarted..............
Old 05-24-2005
hey im trying to install a speedo on my chopper, it's a basic mini chopper speedo with the speedo in the middle the battery signal on the right and lights on the left. It does not have a plug for a drive unit wire or anything like that.
Any ideas of how to install this? thanks
Old 08-19-2008
Re: 4 stroke chopper carb tuning and spedo problem
how do i get the base carb setting on my 110cc 4 stroke chopper
Page generated in 1.45999 seconds with 27 queries
