Old 01-30-2006   #1
Postal Dude's Avatar
2005 L7 badly vibrating, 2006 L7 not.
Hey,
Last weekend i drove my 2005 L7 against my friends 2006 L7 on the go-kart track.. My bike is a standard 47cc and my friend`s a standard 49cc bike.
Now the vibration on my bike is very heavy and my friends bike is as comfy as can be, almost no vibrations!
Anyone knows what the reason can be? Engine mounting is equel in my opinion. Possibly the flywheel or the crank?
Greetz.
Postal Dude is offline   Reply With Quote
Old 01-30-2006   #2
Re: 2005 L7 badly vibrating, 2006 L7 not.
Could be a badly balanced crank, could just be dodgy quality from the factory. I mught help is you check all the mounting screws & bolts and that there in no excess play anywhere.
Mr_Cag is offline   Reply With Quote
Old 01-30-2006   #3
Mmmm, a badly balanced crank is very likely. Engine mounts are all fastened so thats not it. I have not opend up the engine yet cause its running ok.
I might do that when i install a head kit.
I think i`ll try the flywheel mod first though, and see if there is less vibration.
Old 01-30-2006   #4
A good second hand (or even new) crank & flywheel are aprrox sod all $$ from ebay so its not the end of the world, and its very easy to take it all apart and rebuild it.
Old 01-30-2006   #5
yoshirocks702's Avatar
if it wasnt vibrating that bad before check the top engine mount the weld probably broke... same thing happened to me but ill live with it lol
good luck
yoshirocks702 is offline   Reply With Quote
Old 01-30-2006   #6
more likely than anything its your engine i found the same thing for a while in my friends cag vs mine if it has a stock big bore motor in it then it will vibrate like crazy b/c the crank is balanced for the small piston/head. Mine vibrated like crazy i had the stock bb my buddy had the normal 39cc and his was smooth check your motor maybe a big bore. you may not have noticed it lots of people don't. may sound stupid but its happened before
kerrige is offline   Reply With Quote
Old 01-30-2006   #7
d.king's Avatar
If your running a little lean it will run rougher too.
Check your top motor mount to see if its still on tight. They come lose all the time.
DK
d.king is offline   Reply With Quote
Old 01-31-2006   #8
I`ve checked the top engine mount, thats not it. It vibrated since the start. I noticed that it was vibrating more then my friends new bike (wich has a BB as standard) when i rode both on the track, so i know now that these bikes CAN run smoothly.
It`s not that my bike is unrideable, but i now wonder if it is damaging for my engine, especialy because i want to change to a 44mm headkit. If these vibrations kills my enginecases, crank en bearings it would be a waste of money.
Old 02-01-2006   #9
Would a 44mm headkit on my stock 40mm crank make it vibrate even more? because that is a bigger and heavier piston?
Old 02-01-2006   #10
That depends on which bit is currently out of balance. If the crank is too heavy then, yes, a heavier (44mm) piston will help to balance it out. However, if the current piston is to heavy for the crank then swapping to a heavier the 44mm piston will make it hugely out of balance! If you've got the parts you could just try it and hope it makes it better, it's sods law it won't tho. If you do - don't go mad with the revs either cos if it is more out of ballance it is trying to rip itself appart, and most likey will at high RPM's.
Old 02-02-2006   #11
Thanks Mr Cag,
I`ll have a go with the lightened flywheel mod first. Don`t think that it will do much harm because the flywheel isn`t balanced in the first place?
Mayby i`ll notice some difference.
Then i`ll have a go with two extra engine mounts to reduce vibration even more. I`m hoping to test these improvements on the track in two weeks time. I`ll post my results then.
Old 02-02-2006   #12
if the crank is badly balanced, and you lighten the flywheel, the engine will vibrate even more.
r
rasputin is offline   Reply With Quote
Old 02-03-2006   #13
Indeed, or the flywheel is badly balanced and lightening it will make it vibrate less...
I guess it`s gonna be trail and error. (mainly error hahaha)
Old 03-07-2006   #14
Oke, I`ve been riding with an extra engine mount. This actualy helped, because i could tell it reved out more. Still vibrating though.
Now after a few races on the go kart track it started vibrating more and i think it has finaly destroyed the crankbearings...
So i orderd a Head kit with a new crank witch i am going to install next week. I`ll post the results when i`m done.
Just one question, does anyone know wich type of crankbearings i should order?
Old 03-30-2006   #15
So, i took my engine apart to install the new head kit with a new crank.
The old crank was indeed out of balance a lot.
Installed the new kit and some new bearings and went to the go-kart track just to discover that it had the same problem still!
So i had my flywheel and the one from my friends bike checked. His flywheel is ok but mine was not balanced properly. I had mine machined , so we will see if this is the solution to the vibrating problem.
Page generated in 0.27968 seconds with 60 queries
