Originally Posted by HoT SaUcE Not quite sure, don't flame me if im wrong, but wouldnt you need some kind of engine upgrade to make it go 46MPH, so it wouldn't really be a 47cc. |
ok.. cags are 40cc... get the pbu kit youve got around 47ccs.. get a pipe and some other mods,, you are hitting 13,500 rpms. 7 tooth pinion, stock back sprocket is 46mph. dont tell me you wouldnt get up to rpms with a 7 tooth because the added ccs make more torque and so do other mods, and ive seen a stock cag get up to rpms with a 7 tooth. so, laws of physics show that is possible. however there will be a small amount of drag do factor that in and you have a about 44, but if you get like a 62 rear insteead of a 68 rear..then you have about 51 mph factor drag itll be about 47mph. there you go, you just got served
