Old 10-04-2007   #81
Council Member
sr20hardbody's Avatar
Re: Added a boost port tonight *pics*
it'll run lean if you have an airleak try fixing that first because airleaks rob performance and it's just bad.
Old 05-01-2008   #82
davation's Avatar
Well that is not being very polite or open minded to new members. Not everyone is like that duder.
davation is offline   Reply With Quote
Old 06-02-2008   #83
davation's Avatar
I did this MOD, and I am very impressed with the results. Great thread and instructions.
Old 10-01-2008   #84
PBR Co.'s Avatar
Neat, kudos.
PBR Co. is offline   Reply With Quote
Old 10-03-2008   #85
El-Joppo's Avatar
I did this boost port mod to my stock cylinder and piston, and HOLY #¤&#¤&#¤& did she run after that! It has almost no bottom end, weak middle, but top end is nothing less than insane! This easily lets ur engine rev ALOT higher, so much infact that I dont dare to use that engine to often.. I havent measured the revs, but from the sound of it, I would say this mod threw on 3-4K rpm over stock..atleast..and atleast double power over stock through the rpm gains!!!
A funny story is that I at first thought I had completely wrecked the cylinder from doing this mod, because of the lowlow bottom end, and then it suddenly sort of "kicked in" when it got some revs, and boy did it kick in too, u should have seen the grin on my face.. With a proper racing pipe, and adjustable clutch this little engine truly can kick ***!
El-Joppo is offline   Reply With Quote
Old 10-08-2008   #86
PBR Co.'s Avatar
Neat....btw bryan666999 neat paint job....pro, kudos
Old 10-30-2008   #87
KevinT's Avatar
so what is better? 1 boost port or 2? i prefer 1 as it seems more reliable and less likely to cause a cylinder to crack
here is my "homemade" 3rd port on a 44mm bore cag
http://img150.imageshack.us/img150/7751/1000607zz9.jpg
KevinT is offline   Reply With Quote
Old 10-31-2008   #88
skoggy's Avatar
Nice job.. I did the same on a 39cc head and have my spare 44 to do this winter..back up for my scorpion head kit which has 1 big 1 and runs wicked hard
skoggy is offline   Reply With Quote
Old 11-01-2008   #89
eeden01's Avatar
Can any one plz put on a before and after porting pic of the stock head. this will so much help to me!!!
eeden01 is offline   Reply With Quote
Old 11-01-2008   #90
PBR Co.'s Avatar
yo eeden 01! Cagllari/Daytona?
Old 11-04-2008   #91
eeden01's Avatar
lol think its a cagllari.
Bike is known as a RSA or LUCKY7 if that any help...
Old 11-04-2008   #92
thestone11's Avatar
Do you mean your bike in the avatar? if yes, that's not a lucky 7. Lucky 7 is a full fairings and has removable swing arm. The one in your avatar is a Half fairing cag.
Old 11-05-2008   #93
eeden01's Avatar
Smile Re: Added a boost port tonight *pics*
I took the end fairing off... but anyway thats what they told me.
think its the 49cc, one where the fins are non continues around the head.
Just some pics and tips on porting this motor will help lots!!!
Old 11-16-2008   #94
2 STROKER
mx3rider's Avatar
Originally Posted by 42F67N View Post
I have the pos redline motorsports pipe its a total waste looks better is about it,i did my carb boring tonight also I tapered the bore coming in and going out and port matched the reed block to it,i also tapered my needle
Guess ill see how it works out lol
how do you taper your needle?
Old 11-17-2008   #95
thestone11's Avatar
basically take your needle and put into a electrical drill and slowly grind the sharp pointy tips on a fine sand paper. There is a how-to post....
How to: Adjust needle clip *pics*
Old 11-17-2008   #96
eeden01's Avatar
For a boost port the save thing to do is go same height as transfer ports or even 1/2mm lower?
Old 11-19-2008   #97
Originally Posted by zero4 View Post
What sparks? The barrel is aluminum.....
Plated with nicasil!
florentinowhippy is offline   Reply With Quote
Old 02-23-2009   #98
Bismarck's Avatar
Nice crack pipe
Bismarck is offline   Reply With Quote
Old 02-23-2009   #99
2 STROKER
mx3rider's Avatar
hahaha lol i wouldve never noticed that....
and its not plated with nicasil...go research how much that would cost...its chrome plated
Old 09-18-2009   #100
ok fellaz it seems this thread has stopped.. im not sure cuz im new, but any who i was wondering why in the pics i see ur exhaust/intake ports are beside each other.... how does that work??? at least thats what i think i saw.. please correct me if im wrong but is it possible to have the intake/exhaust port to be rate beside each other?? on my 49cc there across from each other. i have 2 heads a sanren and a mitsubishi. im messin around with the sanren.
sirslaughter09 is offline   Reply With Quote
my boost port numbers Nashport_Native Air Cooled Pocketbikes 5 12-25-2005 10:02 AM
Four boost port BB head review LONG Dallas L7 Air Cooled Pocketbikes 25 05-24-2005 08:31 PM
My 2 Boost Ports ,Exhaust Port, and Piston Window Port!!! Day-Tone-A MX Air Cooled Pocketbikes 74 12-21-2004 11:21 PM
boost port & purge tube??? 2oh6civic 2Stroke Midbikes 4 11-20-2004 04:58 PM
Page generated in 0.41040 seconds with 76 queries
