Originally Posted by Stickboy While putting in a new plug to check the old one on my Hydra A/c I noticed that the front chain connected to the clutch / center Sprocket has more play then I think it should and kinda "slaps" on the chain guard. It sounds like a chain saw and I THINK its gotten louder.
The rear chain is fine and I have tightened it just a tad. Does anyone know who has a B1 rep, If you can tighten this first chain ?
thanks. |
Have you checked if your pinion is loose or backing out? Could it be your clutch drum is out of round? WC C1's are known to have crappy clutch drums. Don't know about the AC's though?
