Old 09-22-2004   #1
Back Wheel Won't Spin At All
Hi all, I've not yet ridden my PB as I'm trying to work out a few things before riding. The back wheel won't spin. I've messed with the back brake adjustments, but it does not appear to be due to brake drag. The chain feels a bit tight, but would this cause the back wheel to not spin at all? Any advice is appreciated.
lowbrowmaster is offline   Reply With Quote
Old 09-22-2004   #2
MelloCag's Avatar
Loosen the rear axle nut a touch but not to loose. This should reduce the tension also on the brake caliper trail arm ad a washer or two between the arm
and frame. Last make certain your tire is aligned correctly to allow free spin.
Old 09-22-2004   #3
canadian mike's Avatar
i've heard that if your motor is mounted with three bolts in the bottom, the single bolt in the middle can sit too deep in the hole, and stop the clutch bell from turning.
canadian mike is offline   Reply With Quote
Old 09-22-2004   #4
Kevin's Avatar
haha yeah, that happened to my cag... i was like ***?!?!
but yeah the bolt can go in and tear apart ur clutch.
Kevin is offline   Reply With Quote
Old 09-22-2004   #5
MelloCag's Avatar
Bolt in the middle? Which style cag is this? Just curious. Mine has three allen screw holding it onto the base plate but they are located on each corner of the motor. The bolts are long though but I just added a washer between the motor and the plate plus this helped to remove stress from the upper motor mount since my motor was sitting a bit low.
Old 09-22-2004   #6
Maybe I should clarify, it spins when I turn it by hand, but there is absolutely no freeness or spin to it at all.
Old 09-22-2004   #7
Oh I would say your problem is chain tension, it shouldn't spin too much, maybe 1 - 1 and half turns (own its own) after you stop spinning it with your hand.
Bikoholic is offline   Reply With Quote
Old 09-22-2004   #8
i was referring to the bolt being in the middle along the side directly below the clutch bell, and this is easily fixed with a couple of washers under the mounting plate against the head of the bolt. my original motor was mounted with four bolts, but on the new motor the clutch side is mounted with one bolt between where the two original bolts were located.
Old 09-22-2004   #9
Thanks Guys!
Old 04-06-2005   #10
Question
I don't get it? I have the exact same problem only the clutch shoes don't grab the bell until you really up it and by then it has only just grabbed and turns the wheel a tiny bit!
Wopachang135 is offline   Reply With Quote
What The? Drive Wheel Don't Spin! Wopachang135 Water Cooled Pocketbikes 3 04-05-2005 07:46 AM
Cag rear wheel super stiff !!!HELP!!! toodles Air Cooled Pocketbikes 19 03-04-2005 02:00 PM
Bike back wheel spins while idleing, Wats going on? VuNYen2002 2Stroke Midbikes 5 03-02-2005 11:30 PM
CAG back wheel Wobble question? ctroost Air Cooled Pocketbikes 2 11-10-2004 05:45 PM
Rear wheel straight or not??? barryallen Air Cooled Pocketbikes 7 09-29-2004 10:27 PM
Page generated in 0.23101 seconds with 45 queries
