Old 11-29-2004   #1
BADAZZ dual STAGE reed KIt has arrived! review soon
alright. i just got it in the mail. thank you badazz toys. in opne minute i will install it and report back
Old 11-29-2004   #2
superman37r1's Avatar
Let me know how they run and also list your bike specs...Thanx
superman37r1 is offline   Reply With Quote
Old 11-29-2004   #3
sss
alright my bike has a wt603 thats it oh yeah and a rocket key. everything was fine on my bike. 38mph top (i have a 7 tooth) acceleration was decent.
I installed the kit and for some reason its not working! it starts...i can get a goin a lil then it wants to die.maybe they are too thick or something. ill get everything straightened out.
Old 11-29-2004   #4
NWminiMoto-M's Avatar
loose the rocket key. Big waste
NWminiMoto-M is offline   Reply With Quote
Old 11-29-2004   #5
hey man, i just got the same reeds in friday. when i put them in my bike wouldnt crank, and when it finally would it would die with any throttle. come to find out, the yellow part of the reeds (the bigger piece with the holes) is too long and they can easliy hang on the cases and get pinched closed between the reed cage and the cases. i found this and just trimmed the corners and bottom a lil, put it back in, cranked right up and had throttle response like it should. you should check that!
cspyy is offline   Reply With Quote
Old 11-29-2004   #6
haha
dude i love you...aha i realized that too...and now it still doesnt work! maybe i have more trimming to do
Old 11-29-2004   #7
and by the way a rocket key is not a waste if you know how to tune
Old 11-29-2004   #8
Spud Warrior's Avatar
im glad you maed this thread. I was gonna order one but since they dont even work, i dont think i will
Spud Warrior is offline   Reply With Quote
Old 11-29-2004   #9
they work you just have to trim them...but i can feel a huuuge topend gain coming on
"hey man, i just got the same reeds in friday. when i put them in my bike wouldnt crank, and when it finally would it would die with any throttle. come to find out, the yellow part of the reeds (the bigger piece with the holes) is too long and they can easliy hang on the cases and get pinched closed between the reed cage and the cases. i found this and just trimmed the corners and bottom a lil, put it back in, cranked right up and had throttle response like it should. you should check that!"
see it works!!
Old 11-29-2004   #10
do you only have to trim the corners or the whole edge
Old 11-29-2004   #11
blah's Avatar
The timing before adding the rocket key is about 34 degrees BTDC, that's fine for a whipper snipper. When you Raise Compression, Increase the mixture going into the engine, add a pipe and generally start making more power the flame speed during combustion increases to the point where it will combust too early. The results are, less power, more heat and more stress on an engine. In A.G. Bells book he has a chart showing the effects of timing advance on electrode temps, just increasing the timing by .75mm raised the electrode temps by 100 degrees celcius ( 212f), the rocket key advances timing about 1.4mm. Either you have not started making much power or you are running very rich.
Old 11-29-2004   #12
dd
huh? is that kinda like zenoahs rc engines are advanced 30 degress already but if you put a rocket key in them they can seize real easy..when i put the rockit key in i noticed a gain...
Old 11-29-2004   #13
and spud warrior to answer your question maybe try tracing your old reed...it requires trimming but i believe its worth it. especially cuz its a good price i mean one reed is usually 15..but u get 2 in a kit for 20
Old 11-29-2004   #14
badazztoyz.com's Avatar
hey sikk i just saw this and also posted on the thread on my messageboard. how much did you have to trim? did you get pics for a write up
Old 11-29-2004   #15
s
i had to trim quite a bit. what i did what..i trimmed the outside...i put my ada reed over each reed and cut them around that reed so it was the same side...then i used a sander rotaty tool bit to corner it and get the sharpness off. it looks nice. AND YES! i have pics! but, first i would like to find out what this can work for me as i have not been able to test it after the trimming...because its later over hear in MA. so yeah, tomoro will be pics outcomes top speed gains power band changes...alot of that good stuff
Old 11-30-2004   #16
it felt just like it did when i had a GAP in my ada reed. when i had my ada i fexed tha gap and it was workin like a champ... so tonight i open up my bike...and what do i find? a gap from the first reed and in the second one. thats two gaps! you can imagina how that killed low and midrange! any gap is bad! so i fixed it by putting part of my old reed under both reeds and now there is no gap at all! i will try it tomoro when i get back fropm school! I hope its good!
Old 11-30-2004   #17
SUX2BU's Avatar
How are you measuring your speed?
SUX2BU is offline   Reply With Quote
Old 11-30-2004   #18
dd
digital speedo 0898 and my gearing is 7 62
Old 11-30-2004   #19
KJDK's Avatar
Here comes the argument that the digital speedos can only read up to 32mph........
KJDK is offline   Reply With Quote
Old 11-30-2004   #20
aaa
they obviously read farther than that. in my opinion i think its just the brand and how close the sensor is to the magnet. my gap is about 2mm which is very close....i also have a bell brand speedo
REVIEW: Billet 4 Petal Reed Setup and billet intake manifold from DDM... jman47cc Air Cooled Pocketbikes 9 08-31-2005 10:56 PM
BadAzzToyz 4 Petal Read Kit Review Ritchey79 Air Cooled Pocketbikes 20 06-14-2005 11:20 AM
The Dual Stage Reed Review sikksikksikk Air Cooled Pocketbikes 2 01-04-2005 09:30 PM
Dual stage reed review today and tomorow sikksikksikk Air Cooled Pocketbikes 42 12-22-2004 01:15 AM
Page generated in 0.33862 seconds with 77 queries
