Old 05-09-2005   #1
tblumer's Avatar
Badazz Powerpipe Review
Badazztoyz Powerpipe Review
Thanks goes out to Chris at Badazztoyz for providing me with the pipe for this test. As always, dealing with Chris is a pleasure and his shipping time was lightning fast.
Overview:
The Powerpipe is the newest addition to the Badazztoyz lineup of Cag speed and performance parts. The pipe is available by itself or in a Stage 1 kit with various go fast parts included. Todays review will be on just the pipe.
As you can tell by the pictures, the pipe bears an uncanny resemblance to the JetPro series of pipes. So right from the start I had a good feeling about the performance capability of the pipe. The kit includes:
- The pipe itself (header and main body w/ silencer)
- Coupling springs
- Exhaust gasket
- Rubber isolating bushing
- Exhaust mounting flange
- Misc. mounting hardware
The craftsmanship of the pipe is excellent, the welds were clean and the plating was well done. There was alittle buffing compound left on the pipe from the factory, but it cleaned off easily with a soft rag. Although I'm not into the flashy parts, this pipe does have a certain "Bling" factor to it.
Test set-up:
My RSA framed cag currently has the following installed:
- 39cc cylinder w/ original BAT Torquer Headkit, ported exhaust
- 14mm wide boost port, piston windowed, running single ring
- Stroker crank w/ dual 2mm head shims installed
- ~.5mm squish
- 14/14 replica carb (BadAzz Carb kit), 82 Jet
- Modified reed block running 2-Stage FG reeds
- 7/70 gearing
- Aluminum stock clutch, stock springs, lightened shoes
The temperature was in the low 70's, I'm running Sunoco Ultra 94 with Klotz full synthetic at 44:1 ratio
Old 05-09-2005   #2
tblumer's Avatar
Installation:
After removing the front fairing and tailpiece, I began the task of removing the IP2 pipe I had been previously running. Although the IP2 exhaust is a great top end pipe, the track I run at is too short for it to be useful. I have never cared for the install and removal difficulty of the IP2, which generally involved unbolting the motor or dropping the forks. That being said, I was now ready to install the Powerpipe.
Due to the Powerpipe being a multi-piece design, I started at the exhaust flange first. I inserted the mounting bolts and lock washers thru the flange and then seated the exhaust gasket over the bolts on the backside and tightened it down. The exhaust gasket seems to be of excellent quality, very thick and durable material cut to match the opening on the flange exactly. Now onto the header tube, which slipped onto the flange perfectly. I fed the main body of the pipe into the frame from behind and it lined up perfectly, not only with the header, but with the rear frame mount as well. After slipping the mounting hardware thru the rubber mounting grommet and tightening it down, I proceeded to attach the coupling springs, having wanted to make sure everything lined up before doing this step. You may not be able to fit the lower fairing without clearancing it for the header pipe. I also made note of how far this pipe is away from the fuel tank and lines compared to the IP2 which nearly touched it until I devised a different mounting arrangement. Overall install time was under 30 minutes.
Note: If you have a RSA (removable swingarm) style bike you will need to cut the rear crossbar for this pipe to fit. I'm 225lbs and didn't notice any flex or handling changes having done this.
Testing:
After installation I took the bike to my local testing area which is an abandoned lot in an industrial zone. Having let the bike warm up for a few minutes, I took it for a spin. I found the bottom end to be alot stronger than the IP2 right from the start, and could bring the front end up quite easily. I played around in the low end for alittle while doing roll-ons and it had a nice snap every time. I then moved on to some high speed runs, from a standing start I found the bike would "get on the pipe" harder and earlier than the IP2 would and would stay on for a longer period of time. I honestly feel the bike gained more power across a wider band then the IP2 and really didn't notice much of a loss in overall top speed. I had previously been in the high 30's/low 40's with the IP2, and although I didn't have a gps or radar gun available at the time of the test, it didn't feel I was too far off of that with the Powerpipe.
Conclusions:
At a fraction of the price of the JetPro, the Badazz Powerpipe is a steal. I'm very pleased with the performance gains across the low to mid range and this pipe should prove to be very competitive on a short to moderate size track. Riders should be able to get back on the power quicker out of a corner than with the top end happy IP2 pipe.
Pros:
- Less expensive than a JetPro
- Quality craftsmanship
- Easy installation
- Strong bottom and mid end power
- Fit stock mounts perfectly
- Bling factor
Cons:
- RSA Cags will need crossbar removed
- Lower fairing modification may be required
To purchase a Powerpipe, drop Chris a line at www.badazztoyz.com
Old 05-09-2005   #3
tblumer's Avatar
Heres some extra pics of the installed pipe
Old 05-09-2005   #4
Dave_O's Avatar
so which pipe is gonna stay on the bike? cause i have the ip2 pipe and thats amazing for its price, i doubt that pipe can come close to an ip2 on the top end
Dave_O is offline   Reply With Quote
Old 05-09-2005   #5
MotoXRyne
Posts: n/a
I doubt your IP2 can compare on low end.
Old 05-09-2005   #6
tblumer's Avatar
You really need to make the choice as to your riding area, our local track is pretty short and twisty with 2 moderate length straights, so the Powerpipe would be in the powerband more than the IP2 would.
Old 05-09-2005   #7
lookes like a fat race pipe to me
bulldog 2 is offline   Reply With Quote
Old 05-09-2005   #8
Nice Review Tim! Looks great, I might get one too, my low end is lacking after alll these performance parts, but what I like is how the ip2 kicks in on top speed, get any numbers? if you can, can you please get me numbers with this pipe and numbers with the ip2 pipe?
Thanks
Old 05-09-2005   #9
hows using twin 2mm spacers working for you?
whatrudoing25 is offline   Reply With Quote
Old 05-10-2005   #10
tblumer's Avatar
the twin spacers are working out great, port duration has improved greatly. If I get a chance after work I'll do alittle port mapping and give some exact durations
Old 05-10-2005   #11
tblumer's Avatar
John, unfortunately my tiny tach came messed up, I have a email in to the company, hopefully I can get it resolved and some #'s for you soon
Old 05-10-2005   #12
Thanks a lot Tim! That sucks about tach, hopefully they will help you and replace it....
John
Old 05-10-2005   #13
Im running the same head and crank with a 5 mm spacer. With a reshaped squish band at .4mm it makes plenty of power and pulls to 13k rpm.
borednstroked is offline   Reply With Quote
Old 05-10-2005   #14
how do these spacers work..i know they do something with port durations but how exactly would you set it up..
wasraceme is offline   Reply With Quote
Old 05-10-2005   #15
MotoXRyne
Posts: n/a
They raise the cylinder up 2mm, so, say the stock transfer ports open ~2mm, adding this spacer will make them open 4mm. You have to run a removable head with this as it is the only way you can lower the top of the cylidner 2mm and restore your squish back to normal.
Old 11-03-2006   #16
Re: Badazz Powerpipe Review
i just wana know what was the top end gains u think w/ the badazz pipe???
lea3734 is offline   Reply With Quote
Old 11-04-2006   #17
TUSCANI's Avatar
Looks Hot.
TUSCANI is offline   Reply With Quote
Old 11-04-2006   #18
would that powerpipe be any good on just a stock cag..
skidmark03 is offline   Reply With Quote
Old 11-05-2006   #19
caferacer's Avatar
Yes it will.
I run this pipe on three of my bikes.
Old 11-05-2006   #20
alright man, thanks alot i will probably buy this
Review of new Badazztoyz Head Kit BAT-HK Ritchey79 Air Cooled Pocketbikes 58 02-06-2006 06:08 PM
BadAzzToyz 4 Petal Read Kit Review Ritchey79 Air Cooled Pocketbikes 20 06-14-2005 11:20 AM
New BadAzz Powerpipe special 89 till sunday badazztoyz.com Air Cooled Pocketbikes 16 04-24-2005 12:10 AM
BADAZZ dual STAGE reed KIt has arrived! review soon sikksikksikk Air Cooled Pocketbikes 30 12-01-2004 07:04 PM
ADA Racing Pipe Review snowboardgeek1 Pocketbike / Mini bike Reviews 0 11-17-2004 01:00 PM
Page generated in 0.40924 seconds with 77 queries
