Old 03-23-2005   #41
they don't mix water with it they supplement it with ethanol. here in lubbock at 3200 ft the ranges are 86,89,91. and we still pay about the same for our 'premium' when it really is only mid grade. also remember that midgrade is made by mixing low grade and premium. cheers
ryan is offline   Reply With Quote
Old 03-23-2005   #42
gmenge's Avatar
Originally Posted by pmr08
here in nashville ive never seen 91 only 87 89 and 93
In Colorado we have 85, 87, 91. In Minnesota we have 87, 89, 93
gmenge is offline   Reply With Quote
Old 03-23-2005   #43
KJDK's Avatar
Here in philadelphia Sunoco carries 94 octane at there pumps. They dont advertise it on there sighns but its there. I cant imagine who buys it though. it Must sit in the tanks for months.
KJDK is offline   Reply With Quote
Old 03-23-2005   #44
Yeh, They mix water....I dont kno what the heck your talking about ryan, but your not correct....lol jp, i just guessed, we get to 91....will 91 octane with 50:1 fully synthetic oil work on the old ritchey head?
John
Old 03-23-2005   #45
Here in sweden we got only 95 and 98 octane,, on all pumps..
but 1 litre of gas cost 1$
//Niklas
Nikel is offline   Reply With Quote
Old 03-23-2005   #46
Ritchey79's Avatar
I'm running 93 octane right now for my tests and my enigne is making 14.3:1 compression. There are zero signs of detonation. You will not be able to run 15:1 on pump gas without adding an octane booster. I can only run pump in mine b/c I have set my plug to the correct specs and the head is capable of dissapating enough heat to prevent spontaneous combustion. I don't know if these heads are capable of doing that on pump gas. When I go to the track and race I only run VP110 race gas, that's 110 octane for those of you who don't race. In racing conditions the engine is being pushed to it's limits for extreme periods of time and simply running pump gas is just asking for problems under those circumstances.
Originally Posted by Day-Tone-A MX
Yeh, For the Old Ritchey One, its ok to run 91-93...but for the new ones 93+ is better then 91.....Im getting the old one cause I cant get 93 octane from the pumps...they only have 91....so im using 91 and 50:1 for my head kit...
John
Old 03-23-2005   #47
1shot1kill's Avatar
yeah i lived in germany for 4 years and it was pretty much the same as sweden. $60 bucks wouldn't fill up a mid-size family sedan. lol
//Niklas
1shot1kill is offline   Reply With Quote
Old 03-23-2005   #48
Originally Posted by Ritchey79
I'm running 93 octane right now for my tests and my enigne is making 14.3:1 compression. There are zero signs of detonation. You will not be able to run 15:1 on pump gas without adding an octane booster. I can only run pump in mine b/c I have set my plug to the correct specs and the head is capable of dissapating enough heat to prevent spontaneous combustion. I don't know if these heads are capable of doing that on pump gas. When I go to the track and race I only run VP110 race gas, that's 110 octane for those of you who don't race. In Racing conditions the engine is being pushed to it's limits for extreme periods of time and simply running pump gas is just asking for problems under those circumstances.
Spontaneous combustion??? Not likely....maybe a pile of gas soaked rags. I think the term you were looking for was pre-ignition......the air/fuel mixture being ignited before the spark plug fires.
borednstroked is offline   Reply With Quote
Old 03-23-2005   #49
Ritchey79's Avatar
Pre ignition, spontaneous combustion pretty much the same thing, the gas is igniting without a flame source. The cylinder walls and head if not cooling fast enough can superheat the fresh unburnt fuel/air charge and actually ignite the mixture spontaneously before the sparkplug is fired. That's all I was trying to say, maybe a poor choice of words on my part. Eitehr way that describes the process of engine detonation.
Old 03-23-2005   #50
1shot1kill's Avatar
hey chris, i just bought the kit! send it to me fast...FAST! lol jk. i just couldn't wait till next week. the more i read ritchey's review, the more i itched for it!
Old 03-23-2005   #51
Skidoo83's Avatar
My cylinder head has BD on the side..What displacement is that?
Skidoo83 is offline   Reply With Quote
Old 03-23-2005   #52
BD is the same as zh-1, sy, squiggly lines....its a 40mm motor....will fit this kit...
John
Old 03-24-2005   #53
pyro_incubis's Avatar
Will this get work with a stock exhaust without mods?
what kinda of gains do you get top end or lowend?
pyro_incubis is offline   Reply With Quote
Old 03-24-2005   #54
badazztoyz.com's Avatar
it will but id suggest getting a pipe anyway or modding yours. With higher compression you move your powerband a little lower so your bike gets on the pipe quicker so you have better throttle response and increased overall power
Old 03-24-2005   #55
gmenge's Avatar
What spark plug comes with this kit? The hole in the dome looks small.
With this head kit and an 4petal reed kit what exhaust would you recommend?
Old 03-25-2005   #56
ill get you the exact plug number tommmorrow when i get to the office..i just dont remember off the top of my head lol exhaust all depends on how you run your bike..I like the ip2 pipe but have heard good things about the jetpro and think you can get that at ddm
Old 03-26-2005   #57
1shot1kill's Avatar
hey what's up? you got that plug # yet?
Old 03-26-2005   #58
c8hsa sorry
Old 03-26-2005   #59
1shot1kill's Avatar
that's a champion plug right? yes? no?
c8hsa sorry
Old 03-26-2005   #60
NGK (taking up space)
New BadAzz Powerpipe special 89 till sunday badazztoyz.com Air Cooled Pocketbikes 16 04-23-2005 11:10 PM
Page generated in 0.52186 seconds with 76 queries
