Old 02-28-2009   #1
Fezikk's Avatar
BBK and reed coming help
okay i ordered the BBK and composite reed set from DDM i got the 44mm kit with the 10mm pistion pin and that will fit my stock crank set up right? and will the composite reed be able to open all the way? or will that slow me down, thats one of the reasons why i didnt order a black widow reed cause i dont have that many modifications on it..
Fezikk is offline   Reply With Quote
Old 02-28-2009   #2
dmicgrif's Avatar
Re: BBK and reed coming help
yeah the stock crank is a 10mm i just ordered the widow reeds before i was told that it will slow me down. so i guess i will have get a lot of mods to the bike now. just so i can use the reeds.
dmicgrif is offline   Reply With Quote
Old 02-28-2009   #3
2 STROKER
mx3rider's Avatar
they will, however snap shut faster for more crankcase comp. but it may make the bike harder to start due to stiffer reeds, which is why my bike is so hard to start and combined with the fact i have a ADA 44mm 17:1 comp. head kit,it makes it hard to pull and hard to start
Old 03-01-2009   #4
javy_trkstr's Avatar
hey mx3 what fuel are u running on that setup?
javy_trkstr is offline   Reply With Quote
Old 03-01-2009   #5
thestone11's Avatar
black widow reeds will work fine with your set up. Internal mods are always link to each other. In an ideal world, for sure it will be better off having the full souped up engine, but step by step wouldn't hurt too but certain combination will give you the most in performance gain. Like headkit, reeds with performance exhaust. I think it is a good time to upgrade to a full circle crank for your engine since you already open up your case.
Old 03-01-2009   #6
2 STROKER
mx3rider's Avatar
havent really taken the time to test it...i have about 20 other mods with it, only thing i havent done to the engine is case porting and a full circle crank
and i need to change the gearing
Old 03-01-2009   #7
Council Member
cbtlr's Avatar
Gear change is a must to get the bang for the bucks out of the bbk.Cant go wrong with the ADA f/g reed.Black widow failed me in less than 10 mins of ride time.
cbtlr is offline   Reply With Quote
Old 03-01-2009   #8
how did the black widow fail you? did u use the reedstop? i dont and thought that might be bad..
Page generated in 0.26765 seconds with 39 queries
