Originally Posted by NinjaSquid yep I have had both The blata is better hands down.
can someone clear up the 6.5 conversion. I keep reading it but everyone keeps coming in on different ways of how they did it and its really confusing.
makes my head hurt.  |
6.5 conversion, let me see if I can clear up some headache... lol
there are 3 ways you can do this...
1. just make a spacer between the front rim and brake rotor.
2. get the whole front end of a cag (forks, triple mounts, brakes, etc...).
3. get the whole front end of a blata elite 13 or any other bike with similar front ends and 6.5 wheels. (I'd rather go with the cag parts lol).
the rear is simple swap but the front may take a bit more work. I went with the complete cag front. I also flipped forks backwards so it wouldn't hit the lower part of the fairing to give you about a 1" to 1 1/2" space. if you decide to not flip it, just cut some of the fairing until it isn't rubbing anymore...
if you go with the spacer, just remove the rotor on the front cag 6.5 rim add a spacer (*option - may need slightly longer bolts) spacer must be matched, just enough for the rotor not to rub on the brake shoes.
you'll notice that you can't swap the sprocket or front and back rotors from the 2.5 over to the cag rim as a direct bolt on, vise versa. and if you plan on using the same one "suggestion" don't make the hole bigger, just make new holes...
hope this clears it up
